I’ve encountered a strange Exception while trying to receive the current power from a Sonoff POW via MQTT.
MQTT itself is running perfectly as are all other transformations via JSONPATH.
This is the exception:
2018-02-12 23:07:18.814 [ERROR] [.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
org.openhab.core.transform.TransformationException: An error occurred while transforming JSON expression.
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) [208:org.openhab.core.compat1x:2.2.0]
at org.openhab.binding.mqtt.internal.MqttMessageSubscriber.processMessage(MqttMessageSubscriber.java:138) [226:org.openhab.binding.mqtt:1.11.0]
at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.messageArrived(MqttBrokerConnection.java:556) [210:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.deliverMessage(CommsCallback.java:475) [210:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:379) [210:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:183) [210:org.openhab.io.transport.mqtt:1.11.0]
This is my items definition (broken in two lines for readability):
Number sonoff_washer_power "Power: [%.1f W]" (group_sonoff)
{ mqtt="<[mosquitto:sonoff_washer/tele/ENERGY:state:JSONPATH($.ENERGY.Power)]" }
and this is the JSON payload of the MQTT message “sonoff_washer/tele/ENERGY”:
{"Time":"2018-02-12T23:07:15","ENERGY":{"Total":1.016,"Yesterday":0.016,"Today":0.014,"Period":0,"Power":0,"Factor":0.00,"Voltage":234,"Current":0.111}}
A very similar JSONPATH transformation works absolutely fine:
Number sonoff_washer_power2 "Power: [%.1f W]" (group_sonoff)
{ mqtt="<[mosquitto:sonoff_washer/stat/STATUS8:state:JSONPATH($.StatusSNS.ENERGY.Power)]" }
JSON payload:
{"StatusSNS":{"Time":"2018-02-12T21:10:19","ENERGY":{"Total":1.014,"Yesterday":0.016,"Today":0.012,"Period":0,"Power":1,"Factor":0.08,"Voltage":230,"Current":0.081}}}
I don’t know how often I checked the syntax of my items definition and found nothing wrong. I copied from the working example multiple times, carefully replacing the relevant parts. But to no avail, the exception is very stable
This one works, but it’s obviously not what I want :
String sonoff_washer_power3 "%s" (group_sonoff)
{ mqtt="<[mosquitto:sonoff_washer/tele/ENERGY:state:default]" }
Has anyone an idea what’s wrong?
