Strange LOG Entries OH 3.4.2 on Synology Docker
  • Platform information: OIpenhab 3.4.2
    • Hardware: Synology Diskstation Docker
    • Java Runtime Environment: which java platform is used and what version ??
    • openHAB version: 3.4.2
I noticed strange entries in my log file regarding:
2023-10-09 14:37:25.108 [WARN ] [org.eclipse.jetty.server.HttpChannel] - www.computerhistory.org:80
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 26
these entries occour every 10 - 90 minutes not realy regularly and not in relation of any activity I apply to openhab.
The entry looks like this :
2023-10-09 14:37:24.789 [WARN ] [org.eclipse.jetty.server.HttpChannel] - www.wikipedia.org:80
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 20
at java.lang.String.checkBoundsBeginEnd(String.java:3319) ~[?:?]
at java.lang.String.substring(String.java:1874) ~[?:?]
at org.ops4j.pax.web.service.spi.model.ServerModel.matchPathToContext(ServerModel.java:370) ~[?:?]
at org.ops4j.pax.web.service.spi.model.ServerModel.matchPathToContext(ServerModel.java:310) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:73) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) ~[bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.46.v20220331]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.46.v20220331]
and what I realize it the change in the first row of the log entrys :
2023-10-09 14:45:12.779 [WARN ] [org.eclipse.jetty.server.HttpChannel] - google.com:443
2023-10-09 14:37:24.279 [WARN ] [org.eclipse.jetty.server.HttpChannel] - www.google.com:80
2023-10-09 13:38:08.058 [WARN ] [org.eclipse.jetty.server.HttpChannel] - duckduckgo.com:443
Does anyone has an idea how to stop these messages or knows were they come from. I red other chats with silimar logs but the answers didn’t make sense to me.
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 18
2023-10-09 13:57:25.872 [WARN ] [org.eclipse.jetty.server.HttpChannel] - google.com:443
java.lang.StringIndexOutOfBoundsException: begin 0, end -1, length 14
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
Something is scanning your network, see:
Easiest way to stop these messages is to not directly connect openhab to the internet.
Your suggestion lead to a disconnection of all mobile openhab apps which I don’'t want to consider right now.
I red the github entry but I assume I’m a bloddy beginner and so could you assist me in trying to find out what happend with my configuration. By reading these comments I unfortunately don’t understand what to improve within my configuration. Hopefully you are willing to give a helping hand
from what wolfgang_s said, it seems that you have opened some ports in your router to access openhab via internet.
Thats bad and there are other ways to do it.
check:
I’ll try to close all ports opened in my router an will report what happend and wether openhab mobile is still running. thanks for your suggestion.
The exceptions are logged because of buggy code in a library openHAB uses. The logging is not harmful but it is annoying.
It is a good idea to restrict access to openHAB as already suggested. Restricting access will prevent this issue and it will also prevent future security issues from being abused.
Besides only allowing access via openHAB Cloud, you can also limit access with firewall rules, using an HTTP proxy in front of openHAB or by only making openHAB accessible via VPN.
Yesterday i closed all open ports of the synology diskstation ( 5000, 8080 and 8443 ) and before restarting the diskstation there were again logfiles form eclipse. But after a complete shutdown and restart of the server including the restart of openhab and mosquitto in dockers my log file showed no strange log entries this morning and mobile access is still granted even with closed ports.So thank you for your comments and I’ll update this chat in one week telling if still the log entries are gone.
