I’m running OpenHab2 with the zwave binding/Aeotec Gen5 zstick and just added a couple of these to my zwave network. They are supposed to support the multilevel switch class, however, if I implement them in an item as such they do not work. Setup as a binary, they do. When setup as a binary switch item they visibly step through several levels like a dimmer when operated.
I am not sure what the problem is, but i have two other Leviton outlets that support most of the same switch classes and behave nothing like this.
I wasn’t sure where this should be posted, but I hope this is the right place. Any guidance is appreciated.
Thanks,
Aaron
