Hi
I’m running OH (actually 3.2) on a Raspberry Pi 1b for some years now.
A few weeks ago my zwave setup (mostly roller shutters controlled by zwave -usb-stick) started to stop working…bad, but now it gets worse:
A few days I thought the some other things/ items in my sidemap won’t. But after a refresh i saw that the ui openhabianpi:8080 e.g. 192.168…:8080 can’t be reached …and the same to the log viewer (:9001). The only possible access was by SSH/Putty.
And now “worse on highest level”: I’ve mounted a vanilla sd-card,new OH-download … and… UI still not available…more: I’ve managed to call the log viewer one time (no entries - i think cause of the vanilla installation)…But now I can’t even get there.
Any suggestions? Is it the dry, hot summer? (Could not really be…installation is in the basement…no more than 31°C.
i’m not sure where to find these correct files - i’ve checked the folder /var/log/openhab … there’s no file there. The “syslog.l” looks inconspicuous … but I am also unsure what to look for.
Something is preventing openHAB from starting. Check your folder permissions. Try to start it manually and see if you can get something useful as an error.
