Stream edit XML
Hi
I want to stream edit an XML when i control my Hikvision Camera.
When I send RESP=$(curl http://admin:XXXXXX@192.168.192.83/ISAPI/Event) i receive this.
I want to be able to remove and reinsert the lines i have marked with ** in the begining of the line.
/Mike
<?xml version="1.0" encoding="UTF-8"?>
<EventNotification version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<EventTriggerList version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<EventTrigger>
<id>IO-1</id>
<eventType>IO</eventType>
<eventDescription>IO Event trigger Information</eventDescription>
<inputIOPortID>1</inputIOPortID>
<videoInputChannelID>1</videoInputChannelID>
<dynVideoInputChannelID>1</dynVideoInputChannelID>
<EventTriggerNotificationList>
</EventTriggerNotificationList>
</EventTrigger>
<EventTrigger>
<id>VMD-1</id>
<eventType>VMD</eventType>
<eventDescription>VMD Event trigger Information</eventDescription>
<EventTriggerNotification>
<id>record-1</id>
<notificationMethod>record</notificationMethod>
<videoInputID>1</videoInputID>
<notificationRecurrence>beginning</notificationRecurrence>
</EventTriggerNotification>
**<EventTriggerNotification>
**<id>center</id>
**<notificationMethod>center</notificationMethod>
**<notificationRecurrence>beginning</notificationRecurrence>
**</EventTriggerNotification>
</EventTrigger>
<EventTrigger>
<id>tamper-1</id>
<eventType>tamperdetection</eventType>
<eventDescription>shelteralarm Event trigger Information</eventDescription>
</EventTrigger>
<EventTrigger>
<id>diskfull</id>
<eventType>diskfull</eventType>
<eventDescription>exception Information</eventDescription>
</EventTrigger>
<EventTrigger>
<id>diskerror</id>
<eventType>diskerror</eventType>
</EventTrigger>
<EventTrigger>
<id>nicbroken</id>
<eventType>nicbroken</eventType>
</EventTrigger>
<EventTrigger>
<id>ipconflict</id>
<eventType>ipconflict</eventType>
</EventTrigger>
<EventTrigger>
<id>illaccess</id>
<eventType>illaccess</eventType>
</EventTrigger>
<EventTrigger>
<id>linedetection-1</id>
<eventType>linedetection</eventType>
<eventDescription>Linedetection Event trigger Information</eventDescription>
</EventTrigger>
<EventTrigger>
<id>fielddetection-1</id>
<eventType>fielddetection</eventType>
<eventDescription>fielddetection Event trigger Information</eventDescription>
</EventTrigger>
<EventTrigger>
<id>videomismatch</id>
<eventType>videomismatch</eventType>
<id>beep</id>
<notificationMethod>beep</notificationMethod>
</EventTrigger>
<EventTrigger>
<id>badvideo</id>
<eventType>badvideo</eventType>
</EventTrigger>
<EventTrigger>
<id>PIR</id>
<eventType>PIR</eventType>
<eventDescription>PIR Event trigger Information</eventDescription>
<id>IO-1</id>
<notificationMethod>IO</notificationMethod>
<outputIOPortID>1</outputIOPortID>
<id>record-1</id>
<id>center</id>
</EventTrigger>
</EventTriggerList>
</EventNotification>
It isn’t clear how you get that into OH. But you should be able to use a JavaScript or XSLT transform to insert the new elements.
I want to have a Switch and include the rows when pressing ON and exclude them when pressing OFF.
/mike
In that case you probably need to use a Rule and manipulate the XML String there.
