Point taken on the logs … I was trying to reduce clutter. Here’s another set of log entries, unredacted.
2020-04-21 13:41:33.655 [ome.event.ItemCommandEvent] - Item 'DownstairsThermostat_FanTimer_Control' received command 10
2020-04-21 13:41:33.657 [vent.ItemStateChangedEvent] - DownstairsThermostat_FanTimer_Control changed from OFF to 10
2020-04-21 13:41:33.671 [ome.event.ItemCommandEvent] - Item 'DownstairsThermostatFanMode' received command 1
2020-04-21 13:41:33.671 [nt.ItemStatePredictedEvent] - DownstairsThermostatFanMode predicted to become 1
2020-04-21 13:41:33.673 [ome.event.ItemCommandEvent] - Item 'DownstairsThermostat_FanTimer_10' received command ON
2020-04-21 13:41:33.679 [vent.ItemStateChangedEvent] - DownstairsThermostatFanMode changed from 0 to 1
2020-04-21 13:41:33.681 [vent.ItemStateChangedEvent] - DownstairsThermostat_FanTimer_Status changed from to Fan autoshutoff expected at 13:51.
2020-04-21 13:41:33.685 [vent.ItemStateChangedEvent] - DownstairsThermostatStatus changed from System: Idle. Fan: Off. Humidity: 46%. Battery: 95%. to System: Idle. Fan: Off. Humidity: 46%. Battery: 95%. Fan autoshutoff expected at 13:51.
2020-04-21 13:41:33.821 [vent.ItemStateChangedEvent] - DownstairsThermostatFanStateLiteral changed from Off to On
2020-04-21 13:41:33.821 [vent.ItemStateChangedEvent] - DownstairsThermostatFanState changed from 0 to 1
2020-04-21 13:41:33.826 [vent.ItemStateChangedEvent] - DownstairsThermostatStatus changed from System: Idle. Fan: Off. Humidity: 46%. Battery: 95%. Fan autoshutoff expected at 13:51. to System: Idle. Fan: On. Humidity: 46%. Battery: 95%. Fan autoshutoff expected at 13:51.
No, the only thing I redacted was the time and source from the log entries. What do you mean by “autoupdate predictions”? The entries that say predicted to become...
? I never really understood that.
Intended. This “Control” is a proxy for a user interface item. This is the rule that turns the fan on or off, and sets the autoshutoff timer if needed (along with some housekeeping like creating status strings, and “cancelling” any other timer that might be running).
Yes, the Honeywell thermostat uses a number of the fan mode: 0=Auto, 1=On, 2=Circulate (a predefined timed fan cycle). Agreed on the bad variable name.
and
I didn’t need to use Strings here; a Switch would have done. I patterned after a different use case where I needed to differentiate between a “rule” ON
and a “device” ON
, so I had rules posting a RESET
to it which in turn tripped a rule to turn it on. Not as elegant as @rlkoshak’s design pattern for that purpose, which I use extensively (and extended to include motion sensors and manage autoshutoff).
As far as ON
vs "ON"
issue, I realize I’ve been inconsistent. In my head, things like ON
and OFF
are just enumerations representing strings. My c# thinking, there, and apparently wrong in this context.
And we have a winner! That’s at least part of my problem … changing all the ON/OFF
to "ON"/"OFF"
is having an effect! I need to clean up some other stuff, but that was very helpful!
Just while troubleshooting, so I could see the state of those timer items.
Yes, this become more complex than I expected. I’ve had problems using timers in other rules. Not really understanding the scope or threading of those timers, I wound up with all kinds of unexpected results when I tried “resetting” them, or turning them “off”. After reading and using the “Proxy Item” approach in your Manual Trigger Detection design pattern, I became enamored of the approach of allowing a proliferation of items to overcome complex rules code. I asked myself why I couldn’t do that for this use case, but I wound up with complex rules code anyway. I guess I need to sharpen my understanding of timers and refactor this.
Thanks to you both for the thoughtful responses!
