I need to update time of the control panel connected to OH. The current date and time should be send one character at a time, HHMMmmddyy should be divided to H, H etc. and sent by
I thought about formatting the date and time into a string and then iterate throug the string char by char. Worst case, to write 10 lines of code, one per each char. Is there a way to get n-th character of a string item?
2015-10-29 20:59:00.049 [INFO ] [org.openhab.model.script.DSC ] - Settime to:2059102915
2015-10-29 20:59:00.064 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule dscSetTime
java.lang.IllegalStateException: Could not invoke method: java.lang.String.charAt(int) on instance: 2059102915
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor46.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_65]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.GeneratedMethodAccessor51.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:767) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor44.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_65]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
... 36 common frames omitted
Does not work, Timestamp is not an item but var of String type, therefore .state method is unknown
2015-10-29 22:24:00.060 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule dscSetTime
java.lang.RuntimeException: The name '<XFeatureCallImplCustom>.state' cannot be resolved to an item or type.
How if I would like to cut out 3 characters after a specific phrase / chanracter?
I have a string: 2016-11-17T14:46:00 act:H dcd:6A ccd:227 orig:0 cat:L'
and would like to get only “6A” (after dcd:) and “227” (after ccd:).
Is this possible with charAt as well?
Thank you so much.
After the dcd: there’s the 2 character string.
How to ignore everything after the blank / space which comes right after the 2 characters?
