I’m trying to create a custom widget with two input parameter, namely the name of the sensor and its temperature. Here is is the code
<div ng-init="ServerPath='../static/temp-data'; IconSet='climacon'">
<link rel="stylesheet" type="text/css" href="{{ServerPath}}/template.css" />
<table id="temp-table">
<tr>
<td colspan="2" align="center" id="temp-device" >"config.temp_name"</td>
</tr>
<tr>
<td align="right"><img id="temp-icon" src="../static/temp-data/climacons/Thermometer-50.png"/></td>
<td id="temp-temp">{{'%.1f' | sprintf:itemValue(config.temp_data)}}</td>
<td align="left" id="temp-sign">°C</td>
</tr>
</table>
but I can’t make the config.temp_name
variable to work. Do you know how to deal with config strings?
Thank you
Francesco
