I’m receiving a date via HTTP binding that is formatted as YYYY-MM-DD. I would like to save as DateTime item, so something like:
DateTime HTTP_Weatherbit_Fore24H_Date "Forecast for [%1$tY-%1$tm-%1$td]" (gOutdoor, gWeather) { http="<[weatherbitFore:10000:JSONPATH($.data[1].valid_date)]"}
the problem is: if I use a String item, I can see the value (eg 2020-05-24). But when I try to convert automatically in DateTime item, using “[%1$tY-%1$tm-%1$td]”, the value of the item is “NULL”.
Any suggestion how to do that? Forced to use a parse rule, or any chance to keep it simpler?
thanks
Andrea
That’s a date, not a datetime, so the default parsing won’t like it much. It probably tells you as much in your log.
If you don’t want to use a rule, you might write yourself a javascript transformation, that can do both the JSON extraction and string manipulation to make a string suitable for a datetime Item.
It’s no simpler than a rule, it does the same work after all.
This is my solution (dunno if the best, but it works :))
rule "Dates from Weatherbit"
Item HTTP_Weatherbit_Fore24H_Date received update or
System started
val Weatherbit_Date = HTTP_Weatherbit_Fore24H_Date.state.toString
val DateTimeType MyDateTimeTypeFromString = DateTimeType.valueOf(Weatherbit_Date)
Converted_Weatherbit_Fore24H_Date.postUpdate(MyDateTimeTypeFromString)
