Im trying to show charts in my sitemap …
I have the database connection working allright … I can see that data is stored in to my (mysql) database… But nothing shows up on the sitemap… just empty sheets…
Greatful for help!
My persistence file (mysql.persist)
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every15Minutes : "0 */15 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
Items {
// persist all items once a day and on every change and restore them from the db at startup
Temperature, Brandv1_temp, Brandv2_temp, Brandv3_temp : strategy = every15Minutes, restoreOnStartup
* : strategy = everyChange, everyDay, restoreOnStartup
And my sitemap code:
Frame label="Temploggning"{
Text label="Yttertemperatur" icon="temperature" {
Switch item=Loggintervall label="Intervall" icon="clock" mappings=[0="Timma", 1="Dag", 2="Vecka"]
Chart item=Temperature period=h refresh=300 visibility=[Loggintervall==0, Loggintervall=="Uninitialized"]
Chart item=Temperature period=D refresh=300 visibility=[Loggintervall==1]
Chart item=Temperature period=W refresh=300 visibility=[Loggintervall==2]
