after over 40 days of normal operation of OH on my PI I’ve run apt-get update then apt-get upgrade.
now I cannot run many commands and are stuck, please help me!
- Platform information:
raspberry PI3
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.4.0-1-rpi2
Platform = none
Uptime = 97 day(s). 9:44:53
CPU Usage = 25.31 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 1.00, 5m: 1.16, 15m: 1.22
Memory = Free: 0.10GB (11%), Used: 0.84GB (89%), Total: 0.94GB
Swap = Free: 0.00GB (0%), Used: 0.00GB (100%), Total: 0.00GB
Root = Free: 25.30GB (91%), Used: 2.20GB (9%), Total: 29.00GB
Updates = 44 apt-get updates available.
Sessions = 1 sessions
Processes = 116 running processes of 32768 maximum processes
PHP = Version: 5.6.33, Memory Limit:
error log:
Installing new version of config file /etc/influxdb/influxdb.conf …
Setting up raspberrypi-bootloader-nokernel (1.20180328-1~nokernel1~jessie) …
Removing ‘diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack’
Removing ‘diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack’
Removing ‘diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack’
Removing ‘diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack’
Removing ‘diversion of /boot/bcm2708-rpi-0-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-0-w.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack’
Removing ‘diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack’
Removing ‘diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack’
Removing ‘diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack’
Removing ‘diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack’
Removing ‘diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack’
Removing ‘diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack’
Removing ‘diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack’
dpkg-divert: error: unable to sync file ‘/boot/overlays/ads7846.dtbo.dpkg-divert.tmp’: Input/output error
dpkg-divert: error: reading package info file ‘/var/lib/dpkg/updates/0000’: Input/output error
/var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: 58: /var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: sync: Input/output error
/var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: 59: /var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: rm: Input/output error
Bus error
[many bus error later…]
/var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: 448: /var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: sync: Input/output error
/var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: 449: /var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: rm: Input/output error
Bus error
/var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: 451: /var/lib/dpkg/info/raspberrypi-bootloader-nokernel.postinst: sync: Input/output error
dpkg: error processing package raspberrypi-bootloader-nokernel (–configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of libraspberrypi0:
libraspberrypi0 depends on raspberrypi-bootloader-nokernel (= 1.20180328-1~nokernel1~jessie); however:
Package raspberrypi-bootloader-nokernel is not configured yet.
dpkg: error processing package libraspberrypi0 (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libraspberrypi-bin:
libraspberrypi-bin depends on libraspberrypi0 (= 1.20180328-1~nokernel1~jessie); however:
Package libraspberrypi0 is not configured yet.
dpkg: error processing package libraspberrypi-bin (–configure):
Processing triggers for libc-bin (2.19-18+deb8u10) …
dpkg: unrecoverable fatal error, aborting:
unable to flush updated status of `libc-bin’: Read-only file system
E: Sub-process /usr/bin/dpkg returned an error code (2)
E: Problem executing scripts DPkg::Post-Invoke ‘if [ -x /usr/bin/etckeeper ]; then etckeeper post-install; fi’
E: Sub-process returned an error code
