Styling the rollershutter card
I am using the rollershutter on a canvas like here:
and I like to style the widget in a different color. As the white background color off the white rounded rectangle stands out too much I would like to make it a bit transparent or greyish.
Frow what I understood I can add a style parameter to the config of the card which I did for the outer card rectangle to make it red (which will not stay but just shows what I did so far):
component: oh-canvas-item
            h: 65
            w: 156
            x: 980
            y: 794
          slots:
            default:
              - component: oh-rollershutter-card
                  dirIconsStyle: arrowtriangle_{dir}
                  item: F1_Shutters
                  style:
                    background-color: rgba(246, 0, 0, 0.8)
My question is how I can change the inner white rectangle of the widget via this config to achieve a “background-color: lightgray;” so it would appear as follows (I tweaked the style with the browser dev tools to show what I intend to do):
The background color for the controls are still just set by the f7 variables. So, in the card style you need to set the --f7-button-bg-color and the --f7-segmented-strong-bg-color variables.
Thanks Justin,
This is how I did it now:
  label: rollershutter_page
blocks:
  - component: oh-block
    config: {}
    slots:
      default:
        - component: oh-grid-row
          config: {}
          slots:
            default:
              - component: oh-grid-col
                config: {}
                slots:
                  default:
                        item: GF_stairs_shutter
                        style:
                          --f7-button-bg-color: rgba(240, 0, 0, 1)
                          --f7-segmented-strong-bg-color: rgba(240, 240, 240, 0.5)
masonry: []
grid: []
canvas: []
Note that the following has no effect
–f7-button-bg-color: rgba(240, 0, 0, 1)
The outcome is
However, if I do this in a fixed canvas widget it results into this and has not effect :frowning:
  h: 65
  w: 137
  x: 564
  y: 2
slots:
  default:
        style:
          --f7-segmented-strong-bg-color: rgba(240, 0, 0, 1)
Question: how do I find out which vars are used. I tried looking into the css source but I can’t figute it out. Where do you get the info from? What if I wanted to give it a thin border for example (without asking you all the time :wink: )
If it’s not one I’m familiar with from my own previous struggles, then I usually just quickly check the component vue file to make sure that there isn’t a direct OH setting for the style I’m trying to control, and if there is not, then I bring up the F7 css doc:
(segmental buttons are under button and don’t have their own doc page).
I looked at the html code which have me these classed:
rollershutter-controls segmented segmented-round segmented-strong
and the div above has 'card-content". Together they define the background-style:
.card-content .segmented
background: var(–f7-card-bg-color);
So by setting this, you can achieve the goal:
style:
  --f7-card-bg-color: rgba(240, 0, 0, 1)
By the way I added this to the yaml of the widget. However, as a sidenote, this can be even done on the page level and it then applies to all widgets for the whole page.
Finally I set it to on the page level to
  style:
    background-color: black
    --f7-card-bg-color: rgba(240, 240, 240, 0.2)
    --f7-button-height: 7px
which IMHO looks pretty nice:
