Hi All,
I’ve taken the below snippet found from the rules example on http://docs.openhab.org/configuration/rules-dsl.html
// increase the counter at midnight
rule "Increase counter"
Time cron "0 0 0 * * ?"
counter = counter + 1
What I’d like to do is the opposite and actually subtract one from the counter instead so that it can be used as a “days until” counter.
Can anyone help?
jeffsf
(Jeff)
2
Umm, counter = counter - 1
isn’t working?
Hmm that’s really weird, I had tried that several times and couldn’t get a success with it so I assumed there was an error with the syntax…
I’ve tried it once again before responding and it has worked?!
Whilst you are here, would you know how to reset the counter once it has reached 0?
rossko57
(Rossko57)
4
I would think something along the lines of if (counter == 0) { do whatever you want …?
