We had a power outtage last night and when the power came back on I noticed that I could not control one of my Zwave lamp switches. I tried doing a heal on the node and reinitialize, but that didn’t work. I then tried a heal on the network but that didn’t work either. I just got home and could not control a different lamp module. I rebooted the server and now when I go into habmin and look a Zwave binding I do not see anything listed. Not even my controller.
Here’s my openhab.log file:
and my zwave.log file:
2016-07-14 15:29:57.236 [INFO ] [.z.internal.ZWaveActiveBinding:337 ]- Update config, port = COM7
2016-07-14 15:29:57.237 [INFO ] [.z.internal.ZWaveActiveBinding:342 ]- Update config, healtime = 2
2016-07-14 15:29:57.247 [INFO ] [b.z.i.protocol.ZWaveController:152 ]- Starting Z-Wave controller
2016-07-14 15:29:57.247 [INFO ] [b.z.i.protocol.ZWaveController:160 ]- Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-07-14 15:29:57.247 [INFO ] [b.z.i.protocol.ZWaveController:326 ]- Connecting to serial port COM7
2016-07-14 15:29:58.551 [INFO ] [b.z.i.protocol.ZWaveController:347 ]- Serial port is initialized
2016-07-14 15:30:06.559 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-07-14 15:30:11.561 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-07-14 15:30:16.564 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-07-14 15:30:21.565 [WARN ] [WaveController$ZWaveSendThread:1355]- NODE 255: Too many retries. Discarding message: Message: class = GetVersion (0x15), type = Request (0x00), payload =
2016-07-14 15:30:26.567 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-07-14 15:30:31.570 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-07-14 15:30:36.572 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-07-14 15:30:41.574 [WARN ] [WaveController$ZWaveSendThread:1355]- NODE 255: Too many retries. Discarding message: Message: class = MemoryGetId (0x20), type = Request (0x00), payload =
2016-07-14 15:30:46.576 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-07-14 15:30:51.579 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-07-14 15:30:56.580 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-07-14 15:31:01.582 [WARN ] [WaveController$ZWaveSendThread:1355]- NODE 255: Too many retries. Discarding message: Message: class = SerialApiGetCapabilities (0x07), type = Request (0x00), payload =
2016-07-14 15:31:06.585 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-07-14 15:31:11.587 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-07-14 15:31:16.589 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-07-14 15:31:21.591 [WARN ] [WaveController$ZWaveSendThread:1355]- NODE 255: Too many retries. Discarding message: Message: class = SerialApiSetTimeouts (0x06), type = Request (0x00), payload = 96 0F
2016-07-14 15:31:26.594 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-07-14 15:31:31.595 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-07-14 15:31:36.597 [ERROR] [WaveController$ZWaveSendThread:1347]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-07-14 15:31:39.204 [ERROR] [eController$ZWaveReceiveThread:1486]- Got I/O exception No error in readByte during receiving. exiting thread.
2016-07-14 15:31:41.600 [WARN ] [WaveController$ZWaveSendThread:1355]- NODE 255: Too many retries. Discarding message: Message: class = GetSucNodeId (0x56), type = Request (0x00), payload =
2016-07-14 15:31:48.557 [WARN ] [veController$WatchDogTimerTask:1604]- Threads not alive, respawning
2016-07-14 15:31:48.558 [ERROR] [WaveController$ZWaveSendThread:1243]- InterruptedException during Z-Wave thread: sendQueue.take {}
java.lang.InterruptedException: null
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:2014) ~[na:1.8.0_60]
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2048) ~[na:1.8.0_60]
at java.util.concurrent.PriorityBlockingQueue.take(PriorityBlockingQueue.java:549) ~[na:1.8.0_60]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveSendThread.run(ZWaveController.java:1240) ~[na:na]
2016-07-14 15:31:48.568 [INFO ] [b.z.i.protocol.ZWaveController:433 ]- Disconnected from serial port
2016-07-14 15:31:48.568 [INFO ] [b.z.i.protocol.ZWaveController:326 ]- Connecting to serial port COM7
2016-07-14 15:31:48.756 [INFO ] [b.z.i.protocol.ZWaveController:347 ]- Serial port is initialized
I did pull the Zstick and reinsert it so you can see that in the log file above.
Does anyone have any idea on what I can do to get these devices back?
