PI3 Openhab2.3
I am still fine tuning my rule using mqtt devices. With a lot of help from the community it is almost done. Now I am getting suddenly tons of messages in openhab.log I do not understand. Maybe some of you know?
Clear some of these are known because the Zwave devices aren´t on but what means… Java shutdown?
ˋˋ2018-07-07 13:02:08.824 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146) [209:org.openhab.io.transport.mqtt:1.12.0]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107) ~[?:?]
… 1 more
2018-07-07 13:02:08.853 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘broker’ was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-07-07 13:02:08.855 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘broker’
2018-07-07 13:02:11.217 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-07-07 13:02:18.866 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘broker’
2018-07-07 13:02:25.500 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2018-07-07 13:02:25.865 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection ‘broker’
2018-07-07 13:02:26.110 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-07-07 13:02:26.676 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-07-07 13:02:26.704 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-07-07 13:02:26.723 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-07-07 13:02:26.753 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-07-07 13:03:02.325 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-07-07 13:03:09.851 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘49.9777766,8.8004107’.
2018-07-07 13:03:11.151 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.58:8080
2018-07-07 13:03:11.158 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.58:8443
2018-07-07 13:03:21.059 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘mqtt.items’
2018-07-07 13:03:21.186 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘fs20.items’
2018-07-07 13:03:21.238 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘G11.items’
2018-07-07 13:03:22.005 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘mapdb.persist’
2018-07-07 13:03:30.002 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘MQTT.rules’, using it anyway:
List is a raw type. References to generic type List should be parameterized
2018-07-07 13:03:30.010 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘MQTT.rules’
2018-07-07 13:03:31.207 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘G11.rules’
2018-07-07 13:03:31.592 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-07-07 13:03:32.263 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘G11.sitemap’
2018-07-07 13:03:33.333 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘zwave_device_296beed3_node4_switch_binary’ for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-07 13:03:33.336 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item ‘zwave_device_296beed3_node4_switch_binary’ for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-07 13:03:33.339 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-07 13:03:36.823 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-07-07 13:03:37.029 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-07-07 13:03:37.676 [INFO ] [b.core.service.AbstractActiveService] - FritzBox refresh Service has been started
2018-07-07 13:03:37.729 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
2018-07-07 13:03:38.048 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-07-07 13:03:38.051 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘broker’
2018-07-07 13:03:38.716 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-07-07 13:03:38.767 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_1,2,19508538) has been shut down
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are: -
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
… 31 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_1,2,19508538) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
… 31 more
2018-07-07 13:03:38.964 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-07-07 13:03:38.969 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //192.168.178.58:8080/rest/sitemaps/G11/G11
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are: -
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions. They are: -
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
… 13 more
at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
… 13 more
… 13 more
2018-07-07 13:03:43.720 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyACM1’
2018-07-07 13:03:43.740 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-07-07 13:03:43.774 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-07-07 13:03:43.802 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-07-07 13:03:43.805 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-07-07 13:03:47.074 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-07-07 13:03:47.078 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 4: Node found
2018-07-07 13:03:47.080 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 5: Node found
2018-07-07 13:03:47.084 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-07-07 13:03:47.086 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-07-07 13:03:47.089 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-07-07 13:03:47.092 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 3
2018-07-07 13:03:47.094 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-07-07 13:03:51.943 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2018-07-07 13:03:57.056 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 4: Is currently marked as failed by the controller!
ˋˋ
