Finally got my side up + gesture events from my Xiaomi cube
My .item is:
Number Pink1CubeButtonEvent { http="<[MiCubePink1GestureCache:500:JSONPATH($.state.buttonevent)]" }
Rule so far (just logging):
rule "Xiaomi Cube action"
Item Pink1CubeButtonLastUpdated changed
Thread::sleep(20)
var actionName = Pink1CubeButtonEvent.state
var name = "Cube P1"
logInfo(name, "Event: " + actionName)
switch(actionName) {
case "MOVE": {
<ACTION>
case "ROTATE_RIGHT": {
<ACTION>
case "ROTATE_LEFT": {
<ACTION>
case "FLIP90": {
<ACTION>
case "FLIP180": {
<ACTION>
case "TAP_TWICE": {
<ACTION>
case "SHAKE_AIR": {
<ACTION>
case "FREE_FALL": {
<ACTION>
case "ALERT": {
<ACTION>
The commented out part is what used to be the parsing of the gestures from the Xiaomi Gateway. That did not contain any info about what face of the cube/dice was up.
Now, the numbers received is coded like this:
x000 for push, so 1000, 2000, 3000, 4000, 5000, 6000;
x00x for double tap, so 1001, 2002, 3003, 4004, 5005, 6006;
x00o for 180° flip (where o = 7 - x), so 1006, 2005, 3004, 4003, 5002, 6001;
x00y for 90° flip (where y ≠ x and y ≠ 7 - x), so 1002, 1003, 1004, 1005, 2001, 2003, 2004, 2006, 3001, 3002, 3005, 3006, 4001, 4002, 4005, 4006, 5001, 5003, 5004, 5006, 6002, 6003, 6004, 6005;
7007 for shake.
7008 for free-fall/drop
7000 for wakeup (the cube sends raw value 2 when I just tap it after a while).
Snippet from.
My log looks like this:
2018-06-09 23:57:45.128 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 7000
2018-06-09 23:57:48.219 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 6003
2018-06-09 23:57:51.339 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 2006
2018-06-09 23:57:54.357 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 7007
2018-06-09 23:58:02.505 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 2000
2018-06-09 23:59:36.117 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 5002
2018-06-10 00:01:05.775 [INFO ] [lipse.smarthome.model.script.Cube P1] - Event: 5005
7000 = wake up (Xiaomi named it ALARM)
6003 = face 6 is up, face was previously up - flip90
2006 = face 2 is up, 6 was up - flip90
7007 = shake
2000 = moved, while face 2 is up
5002 = face 5 is up, 2 was up - flip180
5005 = double tap, face 5 up
What would be the most efficient way to parse these values in the rule?
Possible with a switch(), case construct or a bunch of ifs?
Any suggestions most welcome.
