I am not able to make http binding work and log shows the following issues -
I am using 1.8 version of binding from stable download on OH2
I also tried to install binding from PaperUI which is 1.9b version but gets the same error and none of HTTP commands work - currently i am using Exec binding to call scrips with http commands as a work around - any help will be appreciated.
error below -
2016-10-17 01:43:32.969 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] bind method [addBindingProvider] not found; Component will fail
2016-10-17 01:43:32.971 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] bind method [addBindingProvider] not found
2016-10-17 01:43:32.982 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] bind method [addBindingProvider] not found; Component will fail
2016-10-17 01:43:32.996 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] unbind method [removeBindingProvider] not found; Component will fail
2016-10-17 01:43:32.998 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] unbind method [removeBindingProvider] not found
2016-10-17 01:43:33.004 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] bind method [addBindingProvider] not found
2016-10-17 01:43:33.005 [ERROR] [org.openhab.binding.http ] - [org.openhab.binding.http(206)] unbind method [removeBindingProvider] not found
