IsItDark
is an Object which contains many properties.
One of those properties is its state
Within rules you must tell openHAB what property of the Object you’re comparing your ON
against, because the Object itself isn’t ON
IsItDark
There is also an Astro channel called “astro:sun:local:phase#name” which has the value “DAYLIGHT” between sunrise and sunset and a bunch of of obscure ones inbetween but that should be enough to check against when using !==“DAYLIGHT”
True but , through experimentation. the Nautic
values best suited my purpose and the start is a trigger channel.
Here’s the final
rule “Sunrise Rule - Outside Lights”
Channel 'astro:sun:home:civilDawn#event' triggered START
IsItDark.postUpdate(OFF)
Light_GF_Front_Outside.sendCommand(OFF)
Light_GF_Deck_Outside.sendCommand(OFF)
rule “Sunset Rule - Outside Lights”
Channel 'astro:sun:home:civilDusk#event' triggered START
IsItDark.postUpdate(ON)
Light_GF_Front_Outside.sendCommand(ON)
Light_GF_Deck_Outside.sendCommand(ON)
rule “Keep lights on at night and keep off during the day”
Item Light_GF_Front_Outside received update or
Item Light_GF_Deck_Outside received update
if (IsItDark.state == ON && Light_GF_Front_Outside.state == OFF){
if (IsItDark.state == OFF && Light_GF_Front_Outside.state == ON){
if (IsItDark.state == ON && Light_GF_Deck_Outside.state == OFF){
if (IsItDark.state == OFF && Light_GF_Deck_Outside.state == ON){
