I have the ASTRO binding online and created items for sunset and sunrise. In Basic UI is show the time the sun rises and when it sets.
In a rule I have defined a static time to switch on the lights in the garden and off.
I have read that using sunrise and sunset events triggered is not that easy.
What is was thinking.
Can I use the time of sunrise and sunset in the astro binding as a variable in my rule? So instead of a fixed time I could use the astro time (which I already display) as a variable. Would this work? And since I am a scripting noob, how would one create that rule?
The channel generates 2 events START and END
That’s because the sun is a disc not a point so the sunset will START when the sunset starts to disappear below the horizon and END when the sun disappears completely below the horizon.
rule "Sunset Rule"
Channel 'astro:sun:local:set#event' triggered START
// Do what you want to do at start of sunset for example:
// Outside_Lights.sendCommand(ON)
rule "Sunrise Rule"
Channel 'astro:sun:local:rise#event' triggered START
// Outside_Lights.sendCommand(OFF)
I recommend using civildawn to turn off the lights in the morning. It’s normally 1 to 2 hours before sunrise and bright enough for cameras and human vision.
It will save you a significant amout of electricity over the year.
rule "Sunset Rule"
Channel "astro:sun:local:civilDusk#event" triggered START
GF_Tuinhuis_Light.sendCommand(ON)
GF_Voordeur_Light.sendCommand(ON)
GF_Achterdeur_Light.sendCommand(ON)
rule "Sunrise Rule"
Channel "astro:sun:local:civilDawn#event" triggered START
GF_Tuinhuis_Light.sendCommand(OFF)
GF_Voordeur_Light.sendCommand(OFF)
GF_Achterdeur_Light.sendCommand(OFF)
I don’t see anything in the logs. I see the triggered START but nothing else
2018-06-22 21:28:03.993 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 21:29:03.208 [vent.ItemStateChangedEvent] - Sonos_State_diningroom changed from PAUSED_PLAYBACK to STOPPED
2018-06-22 21:29:55.262 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 21:30:17.463 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 21:30:50.770 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 21:31:01.860 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 21:33:02.149 [vent.ItemStateChangedEvent] - Zon_straling_dif changed from 20.40 to 0.00
2018-06-22 21:33:02.155 [vent.ItemStateChangedEvent] - Zon_straling_tot changed from 20.44 to 0.00
2018-06-22 21:33:04.436 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 22.5625 °C to 22.5 °C
2018-06-22 21:48:04.444 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 22.5 °C to 21.9375 °C
2018-06-22 21:57:00.008 [vent.ChannelTriggeredEvent] - astro:sun:local:daylight#event triggered END
2018-06-22 21:57:00.021 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered START
2018-06-22 22:01:00.006 [vent.ChannelTriggeredEvent] - astro:sun:local:civilDusk#event triggered START
2018-06-22 22:01:00.014 [vent.ChannelTriggeredEvent] - astro:sun:local:set#event triggered END
2018-06-22 22:08:04.462 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 21.9375 °C to 21.875 °C
2018-06-22 22:18:04.449 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 21.875 °C to 21.9375 °C
2018-06-22 22:23:04.466 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 21.9375 °C to 22.5 °C
2018-06-22 22:36:46.281 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 22:37:08.489 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 22:38:04.455 [vent.ItemStateChangedEvent] - GF_Kitchen_Temperature changed from 22.5 °C to 22.5625 °C
2018-06-22 22:38:15.364 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 22:38:26.461 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 22:38:48.668 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 22:38:59.771 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 22:39:10.863 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 22:39:21.964 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 22:39:33.074 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.9375 °C to 22.875 °C
2018-06-22 22:41:12.983 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.875 °C to 22.9375 °C
2018-06-22 22:41:24.097 [vent.ItemStateChangedEvent] - GF_Jornt_Temperature changed from 22.937
The astro event channels are not triggering the following rules, and I don’t know why.
// Do not operate the roller shutters if the outside temperature is lower than MIN_TEMP
val MIN_TEMP = 3.0|°C
rule "sunrise shutter rule"
Channel 'astro:sun:home:rise#event' triggered START //* DEBUG: */ or Item AT_GuestRoom_Light_Toggle changed to ON
if (Weather_OWM_Current_Temperature.state > MIN_TEMP) {
logInfo("SunRiseShutterRule", "Roller shutters will open automatically at sunrise, temperature (" + Weather_OWM_Current_Temperature.state + ") above " + MIN_TEMP)
gShutter.members.forEach[ s | s.sendCommand(UP) ]
} else {
logWarn("SunRiseShutterRule", "Roller shutters will NOT open automatically at sunrise, temperature (" + Weather_OWM_Current_Temperature.state + ") below " + MIN_TEMP)
rule "sunset shutter rule"
Channel 'astro:sun:home:set#event' triggered START //* DEBUG: */ or Item AT_GuestRoom_Light_Toggle changed to OFF
logInfo("SunSetShutterRule", "Roller shutters will close automatically at sunset, temperature (" + Weather_OWM_Current_Temperature.state + ") above " + MIN_TEMP)
gShutter.members.forEach[ s | s.sendCommand(DOWN) ]
} else {
logWarn("SunSetShutterRule", "Roller shutters will NOT close automatically at sunset, temperature (" + Weather_OWM_Current_Temperature.state + ") below " + MIN_TEMP)
I’m running OpenHAB 2.4.0 with the astro bindings from 2.4.0. I can pick sunrise and sunset times in my sitemap so the astro bindings are active.
What I see in the openhab.log file, is a set of off-by-one-minute NTP messages in the vicinity of astro events:
2019-02-13 07:59:16.584 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T07:58:16.577+0100 to 2019-02-13T07:59:16.578+0100
2019-02-13 07:59:16.584 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 07:58:16 CET to 2019-02-13 07:59:16 CET
2019-02-13 08:00:16.584 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T07:59:16.578+0100 to 2019-02-13T08:00:16.579+0100
2019-02-13 08:00:16.585 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 07:59:16 CET to 2019-02-13 08:00:16 CET
2019-02-13 08:01:00.011 [vent.ItemStateChangedEvent] - astro_sun_local_phase_name changed from CIVIL_DAWN to SUN_RISE
2019-02-13 08:01:00.011 [vent.ChannelTriggeredEvent] - astro:sun:local:civilDawn#event triggered END
2019-02-13 08:01:00.011 [vent.ChannelTriggeredEvent] - astro:sun:local:rise#event triggered START
2019-02-13 08:01:16.587 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:00:16.579+0100 to 2019-02-13T08:01:16.580+0100
2019-02-13 08:01:16.588 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:00:16 CET to 2019-02-13 08:01:16 CET
2019-02-13 08:02:16.587 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:01:16.580+0100 to 2019-02-13T08:02:16.581+0100
2019-02-13 08:02:16.588 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:01:16 CET to 2019-02-13 08:02:16 CET
2019-02-13 08:03:16.588 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:02:16.581+0100 to 2019-02-13T08:03:16.582+0100
2019-02-13 08:03:16.589 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:02:16 CET to 2019-02-13 08:03:16 CET
2019-02-13 08:04:06.775 [vent.ItemStateChangedEvent] - astro_moon_local_phase_ageDegree changed from 101.65688965034964 ° to 101.6988476923077 °
2019-02-13 08:04:06.776 [vent.ItemStateChangedEvent] - astro_moon_local_phase_agePercent changed from 28.2380249028749 % to 28.249679914529914 %
2019-02-13 08:04:06.777 [vent.ItemStateChangedEvent] - astro_moon_local_phase_illumination changed from 53.77601701689767 % to 53.81298729142882 %
2019-02-13 08:04:06.779 [vent.ItemStateChangedEvent] - astro_moon_local_distance_date changed from 2019-02-13T07:59:06.761+0100 to 2019-02-13T08:04:06.761+0100
2019-02-13 08:04:06.780 [vent.ItemStateChangedEvent] - astro_moon_local_distance_distance changed from 382934.87215741887 km to 382914.4390588954 km
2019-02-13 08:04:06.780 [vent.ItemStateChangedEvent] - astro_moon_local_position_azimuth changed from 15.36651222933914 ° to 16.596196739669047 °
2019-02-13 08:04:06.781 [vent.ItemStateChangedEvent] - astro_moon_local_position_elevation changed from -22.826291216574464 ° to -22.607248377443078 °
2019-02-13 08:04:07.825 [vent.ItemStateChangedEvent] - astro_sun_local_position_azimuth changed from 110.49255670054949 ° to 111.46158749511538 °
2019-02-13 08:04:07.826 [vent.ItemStateChangedEvent] - astro_sun_local_position_elevation changed from -1.0661384855205718 ° to -0.3326363437178504 °
2019-02-13 08:04:07.826 [vent.ItemStateChangedEvent] - astro_sun_local_position_shadeLength changed from -53.74 to -172.25
2019-02-13 08:04:07.826 [vent.ItemStateChangedEvent] - astro_sun_local_phase_name changed from SUN_RISE to UNDEF
2019-02-13 08:04:16.636 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:03:16.582+0100 to 2019-02-13T08:04:16.632+0100
2019-02-13 08:04:16.637 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:03:16 CET to 2019-02-13 08:04:16 CET
2019-02-13 08:05:00.007 [vent.ChannelTriggeredEvent] - astro:sun:local:daylight#event triggered START
2019-02-13 08:05:00.013 [vent.ChannelTriggeredEvent] - astro:sun:local:rise#event triggered END
2019-02-13 08:05:00.014 [vent.ItemStateChangedEvent] - astro_sun_local_phase_name changed from UNDEF to DAYLIGHT
2019-02-13 08:05:16.638 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:04:16.632+0100 to 2019-02-13T08:05:16.633+0100
2019-02-13 08:05:16.639 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:04:16 CET to 2019-02-13 08:05:16 CET
2019-02-13 08:06:16.640 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:05:16.633+0100 to 2019-02-13T08:06:16.634+0100
2019-02-13 08:06:16.641 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:05:16 CET to 2019-02-13 08:06:16 CET
2019-02-13 08:07:16.640 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:06:16.634+0100 to 2019-02-13T08:07:16.635+0100
2019-02-13 08:07:16.641 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:06:16 CET to 2019-02-13 08:07:16 CET
2019-02-13 08:08:16.641 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-13T08:07:16.635+0100 to 2019-02-13T08:08:16.637+0100
2019-02-13 08:08:16.642 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-13 08:07:16 CET to 2019-02-13 08:08:16 CET
