Sunset minus 30 minutes
I have a bunch of lighting rules working fine in terms of triggering at sunset:
rule "Living Room Lamp ON"
		Channel "astro:sun:local:set#event" triggered START
		SmartSwitch2_Switch.sendCommand(ON)
My question is, how can I modify the trigger to turn on 30 minutes earlier? As its a bit dark by the time it all turns on.
https://docs.openhab.org/addons/bindings/astro/readme.html#channel-config
Create new item switch with offset, it will switch ON and immediately switch OFF - so then create a rule waiting for ON trigger on that new switch.
// switch will go on 10 minutes before sunset:
Switch Sunset_Time_10 {astro="planet=sun, type=set, property=end, offset=-10"}
    Item Sunset_Time_10 received update ON
Unfortunately that is the old item syntax for the astro1 binding. With the astro2 binding the offset is configured in the channel syntax.
Aaaaah, it seems that I did not update my Astro binding for ages :grinning: You are right, so sorry for any inconvenience caused using astro1 syntax in astro2 binding …
Did you find a solution that you can share ?
Use the “offset” option of your astro-thing for that.
astro:sun:timer  [ geolocation="xxxx,xxxx,xxx", interval=60 ] {
    Channels:
        Type rangeEvent : set#event [
            offset=-30
Then simply use that as a trigger for you event:
rule "Sunset-timer with offset"
    Channel "astro:sun:timer:set#event" triggered START
