I’m trying to create a Sunset rule using the Paper UI experimental rule engine, but there is no ‘trigger’ that matches what the Astro item produces. The Astro item produces the following events:
2017-08-03 20:53:00.029 [ChannelTriggeredEvent ] - astro:sun:local:daylight#event triggered END
2017-08-03 20:57:00.007 [ChannelTriggeredEvent ] - astro:sun:local:civilDusk#event triggered START
2017-08-03 20:57:00.022 [ChannelTriggeredEvent ] - astro:sun:local:set#event triggered END
But ‘END, START’ are not offered in the ‘state’ drop down, in the rule engine.
Is it me being stupid, or is it a current limitation of the ‘experimental’ rule engine?
Bump!
Can nobody help, as I’m stuck?
