I have a sunset time rule that is launching perfectly.
rule "Licht Voordeur aan" when Item Sunset_Event received update ON then sendCommand(Licht_BG_BV, ON) end
I have a second rule that stops the sunset time rule.
rule "Licht Voordeur uit" when Time cron "0 00 22 * * ?" // dagelijks 22:00 then sendCommand(Licht_BG_BV, OFF) end
But when the time of sunset is later than the time set in the second rule the light is switching on and not off anymore.
How can I combine these rules so that if the sunset time is later than the light off his not launching.
I haven’t tested it, but it should look something like:
import org.joda.time.*
// determine time to check
var DateTime timecheck = parse( "" + now.toLocalDate.toDateTimeAtStartOfDay ).plusHours(22)
if (now < timecheck) {
If it’s not working, that’s probably because the variable types of now and timecheck do not yet match. Let me know if you need any help.
