I’m currently using OpenHABian 1.4.1 (running OpenHAb 2.3.0) on a Raspberry Pi Model B Rev 2.
The current kernel is 4.9.35+.
Today I tried to upgrade my system, but seems to be on the newest version already.
I’m trying to access a DS2438 chip via 1-wire. I’m already using a DS18B20 (temperature sensors) without problems. The DS2438 is supported by newer linux kernels.
Now by questions:
Is there a newer kernel available?
Is it possible to install a newer kernel with OpenHabian?
I there a (supported/recommended) way to install a additional kernel module?
If OpenHABian stick with the current kernel version, will the driver be backported to the currently used kernel?
It’s a small but useful driver and it should be easy to do so: https://github.com/raspberrypi/linux/issues/2246
Regards
Sven
PS: Sorry, if this is the wrong group, but I didn’t found a better one…
openHABian is just a bunch of scripts to set up and configure Raspbian Jessy. So the answers to all your questions are more likely to be found on an RPi forum than an OH forum.
The Raspbian Jessy has a stable branch with the 4.9.x kernel that openHABian is using. Is this the same branch openHABian is based on?
If so, why are we currently using 4.9.35 while the latest Raspbian is 4.9.80?
What is the recommended way to only upgrade the kernel (in the 4.9.x branch)? Should I use rpi-update for this or will this upgrade to the newest available 4.x kernel (currently 4.18.x)?
Hmmm?!
I looked at the RPi forum and the answer would be to install the newer version
of the kernel.
A rpi-update 5c80565c5c0c7f820258c792a98b56f22db2dd03 should do the job, but the problem is: “rpi-update” is missing.
So? What to do?
Does the next version (1.5?) use the newer kernel?
Any other ideas?
Did really nobody upgrade the kernel?
Probably not. Most people stick with stock. There is enough that can go wrong already to be playing around with alpha and beta level kernels and drivers.
