This setup is fully integrated within OH:
Available commands “open”, “close”, “toggle” and “venting”,
available status types “is open”, “is closed”, “on the move” and “somewhere stopped in the middle”.
The light barrier is wired straight to the designated terminal block within the SupraMatic and ensures safe operation. To use all the features offered by the “UAP 1” you have to connect 3 contacts and 4 relays triggered by a short pulse. So you need one more device for bridging the UAP 1 to OH. I’m using “HomeMatic wired” anyway and so I stuck to it.
@yves If you can’t use a wireless device but have LAN available - every simple “Arduino Ethernet” should do the job!
All stirred together in a virtual rollershutter item I faced the lack of a “moving garagedoor” within the garagedoor icon set, so here is my little artwork
Something like this, just place them in a location where they make physical contact with the door in open or closed position. If neither contact is closed, the door is moving. If neither contact is closed for more than a few seconds, the door got stuck:
I’m using a lot of Anel Hut’s in our house, I guess i can use that one where you use a homematic device.
when you say "connect 3 contacts and 4 relays triggered by a short pulse. "
I assume this is all connected to your homematic?
so the statusses etc, are not given directly to any Hörmann api?
Yes, the SupraMatic is wired to the UAP 1 by a bus cable (RS 485 Hörmann specific protocol). And the UAP 1 is hooked up to my HomeMatic stuff. UAP 1 is a just a hardware interface. Please refer to the schematic on page 3.
We visited today a supplier for hormann, yet when I look at the documentation we got, we don’t see a * interface “Hörmann UAP 1”
did you buy this with your garage door?
If i’m correct the safety light barrier “Hörmann EL 101” is standard part of a "Hörmann SupraMatic P, Series 3” or at least it seems to be part of it in Belgium.
In germany the light barrier is included with supramatic p series 3 too. This is the only one, which has included sensors for opened, closed and so on… With other motors, you have to use reed contacts on your own. So i would always recommend the supramatic 3.
Uap1 is an extra, you can buy this from your dealer or from the internet.
Edit:
Maybe it would be cheaper to use my knx modul from ing. Budde, see one of my previous posts… You only need a knx ip interface or taspi with tpuart knx usb stick and the ing.budde modul.
I agree, I have heard good things about the KNX module mentioned earlier in the thread. I use UAP1 as well, where you get the relevant contacts and you can use switches to control the door. At the end of the day, those are connected into my KNX system, so that I can control everything via openHAB using the KNX bus.
If the KNX module had been available at the time, i would have used that instead of using three channels on my switch actor and three binary inputs (to get the open, closed, air vent positions).
we don’t have knx in our system. Not against it, yet it sounds like UAP1 might also connect to an anel hut and then have that one send me open/close events.
I also own a Hoermann Garage door and even bought their gateway to be able to use an App for controlling the door.
The goal was always to incorporate the garage door in openhab or at least IFTT, but it seems that won’t happen anytime soon.
So I started to reverse engineer the protocol used between the App and the gatway to be able to build a openhab binding with the findings
Still in an early state, the current work can be found here:
This is still not a binding, but will be the base for one.
I wanted to order a horman garage door this week.
I have always been looking at an UAP1 as a way to connect to openhab.
Now I see that the gateway could be another option (and a better one)
I assume you don’t need an UAP1 for that, or is that needed for the gateway to work?
Where can I find technical info on how to connect/install the gateway?
(I try to understand more on how this works, before contacted the supplier, so I’m sure I ask the right questions, as the sales people are less technical and try to sell their own integrated services which I don’t want …
