i buy on amazon ihomma wifi led downlight but there is no support for this.
Someone can help me
Tanx
It looks like the light is controlled with a sonoff!!!
Open that box and flash the tasmotta firmware on it:
No, that’s just a power supply unfortunately.
The Wifi control must be inside the light itself.
Anyway to open that?
This is indeed an ESP module
You should be able to flash Tasmota on it
Unfortunately your particular device is not named in: https://blakadder.github.io/templates/
But search the repository because you may find a device very similar to yours sold under a different name
If you have no luck, you can follow this guide:https://www.youtube.com/watch?v=BHzsWwd351I&t=2s
I recommend following this guide:
I soldered wires directly to the module and flashed it via serial-to-USB adapter.
Tasmota template
{“NAME”:“iHomma”,“GPIO”:[0,0,0,0,40,41,0,0,37,38,39,0,0],“FLAG”:0,“BASE”:18}
only to be sure: your
is an RGB Led bulb ?
Yes, it is RGB + Cold White + Warm White. I bought it at banggood.com, but it’s not available now.
I prefer LED bulbs with Tuya because there is a chance that they can be flashed with the tuya-convert.
