Folks - Trying to add a one of the door sensors and it’s showing up as “unknown device.” I believe they’re the same as various brands discussed in this thread.
FWIW these worked with mios…
From labels on the device (I can post photos if that helps):
Model: DWZWAVE1
FCC ID: XQC-DWZ1
IC: 9863B-DWZ1
Debug logs below for opening door, then removing cover, then removing/reinstalling battery, reinstalling cover, and closing door:
2020-08-08 23:10:57.875 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 04 08 03 30 03 FF 31
2020-08-08 23:10:57.880 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 03 30 03 FF
2020-08-08 23:10:57.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 03 30 03 FF
2020-08-08 23:10:57.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-08 23:10:57.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Application Command Request (ALIVE:DONE)
2020-08-08 23:10:57.891 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: resetResendCount initComplete=true isDead=false
2020-08-08 23:10:57.895 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-08-08 23:10:57.897 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: SECURITY not supported
2020-08-08 23:10:57.900 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 8: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-08-08 23:10:57.903 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 8: Sensor Binary report, type=Unknown, value=255
2020-08-08 23:10:57.906 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-08-08 23:10:57.909 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2020-08-08 23:10:57.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Commands processed 1.
2020-08-08 23:10:57.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6d8de613.
2020-08-08 23:10:57.916 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:10:57.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:10:57.919 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:10:57.922 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-08 23:11:02.593 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 04 08 0A 71 05 00 FF 00 FF 07 03 01 00 9C
2020-08-08 23:11:02.599 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 0A 71 05 00 FF 00 FF 07 03 01 00
2020-08-08 23:11:02.603 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 0A 71 05 00 FF 00 FF 07 03 01 00
2020-08-08 23:11:02.607 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-08 23:11:02.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Application Command Request (ALIVE:DONE)
2020-08-08 23:11:02.615 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: resetResendCount initComplete=true isDead=false
2020-08-08 23:11:02.619 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-08-08 23:11:02.623 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: SECURITY not supported
2020-08-08 23:11:02.627 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 8: Received COMMAND_CLASS_ALARM V2 NOTIFICATION_REPORT
2020-08-08 23:11:02.631 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 8: ALARM report - 0 = 255
2020-08-08 23:11:02.635 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 8: Alarm Type = BURGLAR (0)
2020-08-08 23:11:02.639 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-08-08 23:11:02.641 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-08-08 23:11:02.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Commands processed 1.
2020-08-08 23:11:02.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4a82a4f4.
2020-08-08 23:11:02.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:11:02.651 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:11:02.652 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:02.654 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-08 23:11:24.377 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 49 84 08 0D 04 20 01 30 71 72 86 85 84 80 70 EF 20 8A
2020-08-08 23:11:24.382 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=8, callback=132, payload=84 08 0D 04 20 01 30 71 72 86 85 84 80 70 EF 20
2020-08-08 23:11:24.385 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=8, callback=132, payload=84 08 0D 04 20 01 30 71 72 86 85 84 80 70 EF 20
2020-08-08 23:11:24.388 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-08 23:11:24.390 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2020-08-08 23:11:24.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2020-08-08 23:11:24.396 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=8, callback=132, payload=84 08 0D 04 20 01 30 71 72 86 85 84 80 70 EF 20
2020-08-08 23:11:24.399 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 8: Application update request. Node information received. Transaction null
2020-08-08 23:11:24.401 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: resetResendCount initComplete=true isDead=false
2020-08-08 23:11:24.404 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 8: Application update - no transaction.
2020-08-08 23:11:24.407 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:24.410 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-08 23:11:24.658 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Is awake with 0 messages in the queue
2020-08-08 23:11:24.662 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Start sleep timer at 1000ms
2020-08-08 23:11:24.668 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-08-08 23:11:24.685 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 8: Node Status event - Node is AWAKE
2020-08-08 23:11:25.167 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: WakeupTimerTask 0 Messages waiting, state DONE
2020-08-08 23:11:25.668 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: WakeupTimerTask 0 Messages waiting, state DONE
2020-08-08 23:11:25.669 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: No more messages, go back to sleep
2020-08-08 23:11:25.671 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 8: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2020-08-08 23:11:25.672 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: SECURITY not supported
2020-08-08 23:11:25.673 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2020-08-08 23:11:25.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@34066587
2020-08-08 23:11:25.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Bump transaction 1125 priority from Immediate to Immediate
2020-08-08 23:11:25.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Adding to device queue
2020-08-08 23:11:25.681 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Added 1125 to queue - size 1
2020-08-08 23:11:25.682 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-08 23:11:25.684 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 08 02 84 08 25 24 62
2020-08-08 23:11:25.686 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 8: Sending REQUEST Message = 01 09 00 13 08 02 84 08 25 24 62
2020-08-08 23:11:25.688 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-08-08 23:11:25.689 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-08-08 23:11:25.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1125: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.692 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-08-08 23:11:25.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-08-08 23:11:25.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1125: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.701 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-08-08 23:11:25.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-08-08 23:11:25.704 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:25.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-08-08 23:11:25.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-08-08 23:11:25.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-08-08 23:11:25.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1125: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.711 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-08-08 23:11:25.712 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1125: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.713 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-08-08 23:11:25.715 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: sentData successfully placed on stack.
2020-08-08 23:11:25.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1125: Advanced to WAIT_REQUEST
2020-08-08 23:11:25.717 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: TID 1125: Transaction not completed
2020-08-08 23:11:25.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:25.720 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-08-08 23:11:25.716 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 24 00 00 02 CD
2020-08-08 23:11:25.724 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=36, payload=24 00 00 02
2020-08-08 23:11:25.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=36, payload=24 00 00 02
2020-08-08 23:11:25.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1125: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.734 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-08-08 23:11:25.735 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1125: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 36
2020-08-08 23:11:25.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 1125: (Callback 36)
2020-08-08 23:11:25.741 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-08-08 23:11:25.742 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 1125: callback 36
2020-08-08 23:11:25.744 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=36, payload=24 00 00 02
2020-08-08 23:11:25.757 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 8: SendData Request. CallBack ID = 36, Status = Transmission complete and ACK received(0)
2020-08-08 23:11:25.758 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: resetResendCount initComplete=true isDead=false
2020-08-08 23:11:25.761 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1125: Transaction COMPLETED
2020-08-08 23:11:25.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Response processed after 72ms
2020-08-08 23:11:25.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: TID 1125: Transaction completed
2020-08-08 23:11:25.766 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: notifyTransactionResponse TID:1125 DONE
2020-08-08 23:11:25.768 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-08-08 23:11:25.770 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:25.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-08-08 23:11:25.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 1125: Transaction event listener: DONE: DONE ->
2020-08-08 23:11:25.775 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Went to sleep COMPLETE
2020-08-08 23:11:32.769 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 04 08 03 30 03 00 CE
2020-08-08 23:11:32.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 03 30 03 00
2020-08-08 23:11:32.791 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 03 30 03 00
2020-08-08 23:11:32.794 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-08-08 23:11:32.796 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Application Command Request (ALIVE:DONE)
2020-08-08 23:11:32.798 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: resetResendCount initComplete=true isDead=false
2020-08-08 23:11:32.801 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-08-08 23:11:32.802 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: SECURITY not supported
2020-08-08 23:11:32.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 8: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-08-08 23:11:32.807 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 8: Sensor Binary report, type=Unknown, value=0
2020-08-08 23:11:32.809 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-08-08 23:11:32.811 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2020-08-08 23:11:32.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Commands processed 1.
2020-08-08 23:11:32.815 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@587a2eaa.
2020-08-08 23:11:32.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:11:32.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-08-08 23:11:32.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-08-08 23:11:32.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
