Hi
I have an OH3 installation running on a rasperry Pi3 with Enocen modul. After configuring my new Eltako FMS55ESB smart sensor I realized that the OH Enocean Binding supports only the EEP A5-04-03. This means that I only can use the temperature of the sensor but not other features like humidity and so on. The FSM55ESB supports also the following EEP, which not can be configured on OH3:
D2-14-41 (which includes the data of all built in sensors)
D2-14-40
A5-04-01
A5-04-03
A5-02-05
A5-06-02
A5-06-03
A5-14-05
Is there anyone who can support me with the question following questions:
Is it possible to do a workaround the get also the data from other sensors with the current EEP?
Is the only way to get the other sensors data with the EEP D2-14-41, and therefore the OH3 Binding have to be developed?
I get the following log entries when receiving data:
2021-10-31 19:25:17.798 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Received Sync Byte
2021-10-31 19:25:17.804 [TRACE] [ernal.transceiver.EnOceanTransceiver] - >> Received header, data length 10 optional length 7 packet type 1
2021-10-31 19:25:17.808 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG _4BS for 0413D1E2 payload A5AA01B9080413D1E28000FFFFFFFF4700 received
2021-10-31 19:25:17.812 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.815 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.818 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.820 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.821 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.822 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.824 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.825 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.828 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.829 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.831 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.832 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.833 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.835 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.836 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryVoltage is linked although the handler was already disposed.
2021-10-31 19:25:17.838 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.840 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.842 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.843 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel illumination is linked although the handler was already disposed.
2021-10-31 19:25:17.845 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.846 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.849 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.850 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.851 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.853 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.854 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.856 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.857 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.860 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.861 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.863 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.864 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.865 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.867 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.868 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.874 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.878 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.881 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.882 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TestTemperatureHumiditySensorEltakoEnocean_LastReceived' changed from 2021-10-31T19:24:18.806081+0100 to 2021-10-31T19:25:17.873082+0100
2021-10-31 19:25:17.884 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.886 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.888 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.892 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::logTime: 'storeItemValue':
afterAccess = 14 ms
timeAverage50 = 17 ms
timeAverage100 = 18 ms
timeAverage200 = 19 ms
afterAccessMin = 2 ms
afterAccessMax = 20787 ms
1000Statements = 2133 sec
statementCount = 672
2021-10-31 19:25:17.892 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.894 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.898 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.899 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.901 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.903 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.904 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.906 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.908 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.911 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel temperature is linked although the handler was already disposed.
2021-10-31 19:25:17.912 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.914 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.915 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel rssi is linked although the handler was already disposed.
2021-10-31 19:25:17.917 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel humidity is linked although the handler was already disposed.
2021-10-31 19:25:17.919 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:temperatureHumiditySensor:f424041d7c:FMS55ESB-7c269a7a7e tried checking if channel batteryLevel is linked although the handler was already disposed.
2021-10-31 19:25:17.920 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload A5AA01B9080413D1E280 for 0413D1E2 received
2021-10-31 19:25:17.923 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel lastReceived is linked although the handler was already disposed.
2021-10-31 19:25:17.925 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel repeatCount is linked although the handler was already disposed.
2021-10-31 19:25:17.926 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel illumination is linked although the handler was already disposed.
2021-10-31 19:25:17.928 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBaseSensorHandler of thing enocean:lightSensor:88149863d4 tried checking if channel rssi is linked although the handler was already disposed.
Thanks for any support.
