Since upgrading to IOS 11 I have found that SVGs are not showing properly. Animated ones rotate around the box and some of the built in habpanel icons display with weird horizontal lines.
I found reference to this - not sure if I am near the mark. I tried adding this to the IMG tag inline but made no difference hoping someone can help @ysc is it something you need to be aware of?
Are there animated builtin SVGs in HABPanel?
If it’s custom animated SVGs not rendering well because of a browser bug I probably can’t do much about it.
@Andrew_Pawelski: Had similar problems with the animations on my floorplan SVG. It would help to know, if there´s a concrete css animation that doesn´t work for you?
I have the same issue with chrome since a while. I’m using also the climacon icons. The animation seems to rotate around the wrong center.
It was working correctly before - so I assume the issue came with one of the chrome updates.
