Is there a easy way to do it in basic UI? Currently I use sitemap “cowen” as default in paper, so if I start basic UI a will see a overview about all sitemaps:
But after I selected one it would be nice to switch back without changing the url…
Maybe it is possible to add a function behind the home icon? -> start default sitemap which is configurated in the paper ui:
Hmm it is tricky. Both behaviors makes sense…
But I think with my suggestion we are more flexible
For example. If a user has only one sitemap (maintained in Paper ui) then it make no sense to show the overview. With click on home button it will call the default sitemap.
If a user has several sitemaps and want to see a overview they can let the default sitemap empty or “cowen”. The home button shows then the list of sitemaps.
Is it possible to switch dynamically from openhab browser page between different sitemaps ?
Like replace in classicui.cfg
org.eclipse.smarthome.classicui:defaultSitemap=sitemap1 -> sitemap2
If I am within a sitemap I cannot go to the selection page. So in my case… if I set a default sitemap it’s not possible to switch to another. Any ideas?
Is there any update? I am currently facing the same problem or missing feature. In the App I can easily switch between Sitemaps in the browser there is no easy way to switch between sitemaps. And if I set a “Default Sitemap” for “Basic UI” via “Paper UI” there seem to be no possible way to switch.
