Platform information: Raspberry pi 3 model b Rev 1.2
OS: Rasbian GNU/Linux 9
openHAB version: 2.5.2.1
Since couple of weeks i am unable to turn on/off lights or rollershutters. I am able to switch the buttons in my openhab app but the actuator do not recognize the command anymore…The KNX config file is looking good… IP Adresses of my Raspberry or my KNX IP interface (MDT IP Interface) hasn’t changed. And “Tunnel” is activated as well.i doublechecked the KNX adresses within ETS5 and everything is correct…
No, you have to raise the log level. Use the karaf console:
[23:44:27] openhabian@openhab2:~$ openhab-cli console
Logging in as openhab
Password:
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.5.2
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> log:set DEBUG org.openhab.binding.knx
openhab> log:list
Logger │ Level
ROOT │ WARN
javax.jmdns │ ERROR
javax.mail │ ERROR
org.apache.karaf.jaas.modules.audit │ INFO
org.apache.karaf.kar.internal.KarServiceImpl │ ERROR
org.apache.karaf.shell.ssh.SshUtils │ ERROR
org.apache.karaf.shell.support │ OFF
org.eclipse.lsp4j │ OFF
org.eclipse.smarthome │ INFO
org.jupnp │ ERROR
org.openhab.binding.knx │ DEBUG
org.openhab │ INFO
org.openhab.ui.paper │ WARN
org.openhab.ui.paper.internal │ INFO
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime │ OFF
smarthome.event │ INFO
smarthome.event.InboxUpdatedEvent │ ERROR
smarthome.event.ItemAddedEvent │ ERROR
smarthome.event.ItemRemovedEvent │ ERROR
smarthome.event.ItemStateEvent │ ERROR
smarthome.event.ThingAddedEvent │ ERROR
smarthome.event.ThingRemovedEvent │ ERROR
smarthome.event.ThingStatusInfoEvent │ ERROR
openhab> logout
[23:45:20] openhabian@openhab2:~$
So the first step is to login to karaf. The second step is to set the log level to DEBUG. The third step is to check, if the setting is correct (not essential ) and the last step is to logout from karaf.
To get all information from begin, restart openHAB. Check only openhab.log. (var/log/openhab2/openhab.log) because frontail will give you much to much information in addition.
Hi Udo_Hartmann,
i enabled the debugging on knx and got the following result:
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2020-03-06 18:57:36.767 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Could not send UPNP response: Cannot assign requested address (sendto failed)
2020-03-06 18:59:48.207 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Could not send UPNP response: Cannot assign requested address (sendto failed)
2020-03-06 19:01:48.209 [WARN ] [ueemulation.internal.upnp.UpnpServer] - Could not send UPNP response: Cannot assign requested address (sendto failed)
could be that the hue emulation causes this issue??
do you mean to start “Busmonitor” ? i have started it and check if i get a response - if a get a response i will double check the KNX adresses - hopefully there was no change. i can’t imagine that this will be changed automatically… (i hope so)
