In Basic UI, a numeric value appears next to a Switch’s mappings. I don’t want to display the numeric value, only the text in mappings.
In Items, Thermostat_FanControl and Thermostat_Mode are defined as Numbers.
Number Thermostat_FanControl "FanControl" <fan> (Thermostats, Foyer) {mqtt=">[broker:premise/command/thermostat/fancontrol:command:*:default],<[broker:premise/thermostat/fancontrol:state:default]"}
Number Thermostat_Mode "Mode" <heating> (Thermostats, Foyer) {mqtt=">[broker:premise/command/thermostat/mode:command:*:default],<[broker:premise/thermostat/mode:state:default]"}
In Sitemap, there are defined as Switches with appropriate mappings.
Switch item=Thermostat_Mode label="Hold" mappings=[0="OFF", 2="ON"]
Switch item=Thermostat_FanControl label="Fan Control" mappings=[0="AUTO", 1="ON"]
What am I doing wrong?
EDIT
OpenHAB V2.3
VS Code reports no errors in Items or Sitemap
