I have a question following up on this old post from 2016:
It has been over a year since this thread. The “OLD_LEVEL” virtual channel is a result of this discussion and long since available. Thanks for implementing it, btw!
While this is great, any Switch item linked to this channel behaves like a push button. So in order to set the old dimmer level for a dimmer that got switched off, this switch needs to be switched on. It then immediately returns back to off and the old dimmer level is set. So far, so good. Unfortunately there seems to be no easy way to get a “real” switch out of this. What I mean is one that turns the light off if the switch is set to OFF and back on again (to OLD_LEVEL!) when it is set to ON.
My question is if there is an easy way to achieve this or if a rule is needed. I know this rule would be quite simple. But still… the less code, the better.
So, how did you solve this? Rule or some other “standard” way I 'm not seeing?
Maybe I’m answering my own question. But I wanted to post the current solution, which is based on rules (because I currently don’t know better )
What I want to be able to do is to quickly toggle a dimmer’s state between OFF and OLD_LEVEL while at the same time being able to adjust the level flexibly. The UI will be a HABpanel. Here’s my current setup:
// Link to the actual dimmer (controllable via UI)
Dimmer DimmerDiningRoom "Licht im Esszimmer" {channel="homematic:<...>#LEVEL"}
// Virtual toggle switch (controllable via UI)
Switch DimmerDiningRoomToggle "Licht im Esszimmer ein/aus"
// Auxiliary switch linked to virtual channel. Note: Behaves like a pushbutton
Switch DimmerDiningRoomLastLevel "Letzter Wert Licht im Esszimmer" {channel="homematic:<...>#OLD_LEVEL"}
Those items are controlled by the following rules (which are too complicated for my taste, but here we go):
rule "Dimmer Dining Room Toggle"
Item DimmerDiningRoomToggle changed
* Only change the dimmer item if it is necessary because
* the dimmer item might otherwise change the toggle item
* leading to unwanted behavior.
if (DimmerDiningRoomToggle.state == ON && DimmerDiningRoom.state == 0) {
// Restore the last dimmer level
DimmerDiningRoomLastLevel.sendCommand(ON)
if (DimmerDiningRoomToggle.state == OFF && DimmerDiningRoom.state > 0) {
// Switch the dimmer off
DimmerDiningRoom.sendCommand(0)
rule "Dimmer Dining Room"
Item DimmerDiningRoom changed
if (DimmerDiningRoom.state == 0) {
// The dimmer is OFF
DimmerDiningRoomToggle.postUpdate(OFF)
} else {
// The dimmer is ON
DimmerDiningRoomToggle.postUpdate(ON)
In HABPanel I use a switch (linked to DimmerDiningRoomToggle) and a slider (linked to DimmerDiningRoom):
