When I press the switch it will turn on the light and the slider will move to 100%, but the switch itself shows the off state immediately in the basic UI sitemap. Same with the slider, when I move it to 100%, the switch stays in the off state, while the icon of the switch shows the correct state. Another (related?) issue: slider does not show the percentage. - edit % value seems to be showing in browser, not in iOS.
I have this issue with any of the 4 dimmers in my items below.
Items:
Switch Switch_A "Bamboo Deur" <light> [ "Lighting" ] { channel="rfxcom:lighting4:usb0:switch_17493:command" }
Switch Switch_B "Bamboo Hoek" <light> [ "Lighting" ] { channel="rfxcom:lighting4:usb0:switch_17685:command" }
Switch Switch_C "Staanlamp" <light> [ "Lighting" ] { channel="rfxcom:lighting4:usb0:switch_17733:command" }
Switch Switch_D "Luidspreker Bel" <soundvolume> [ "Switchable" ] { channel="rfxcom:lighting4:usb0:switch_17745:command" }
Dimmer DIMMER_TAFEL "Tafel [%d %%]" <slider> [ "Lighting" ] { channel="zwave:device:52a72468:node2:switch_dimmer" }
Dimmer DIMMER_PLAFOND "Plafond [%d %%]" <slider> [ "Lighting" ] { channel="zwave:device:52a72468:node3:switch_dimmer" }
Dimmer DIMMER_PLAFOND_MIDDEN "Plafond Midden [%d %%]" <slider> [ "Lighting" ] { channel="zwave:device:52a72468:node6:switch_dimmer" }
Dimmer DIMMER_PLAFOND_ZITHOEK "Plafond Zithoek [%d %%]" <slider> [ "Lighting" ] { channel="zwave:device:52a72468:node5:switch_dimmer" }
String HUB_ACTIVITY "[%s]" <video> { channel="harmonyhub:hub:HarmonyHubFonteinstraat:currentActivity" }
String SceneSwitch "Scènes" <colorlight>
Rollershutter SHUTTERS "Rolluiken" [ "Switchable" ] { channel="rfxcom:rfy:2e084c4c:shutter" }
Sitemap:
sitemap home label="Home"{
Frame label="Actviteiten"{
Switch item=HUB_ACTIVITY mappings=["TV Kijken"="TV Kijken", Kodi="Kodi", Radio="Radio", PowerOff="Uit"]
Frame label="Licht Scènes" {
Switch item=SceneSwitch mappings=[MOVIE="Movie", COZY="Cozy", DINNER="Diner",ALL_ON="Alles Aan",ALL_OFF="Alles Uit"]
Frame label="Lichten" {
Switch item=Switch_A
Switch item=Switch_B
Switch item=Switch_C
Switch item=DIMMER_TAFEL
Switch item=DIMMER_PLAFOND
Switch item=DIMMER_PLAFOND_MIDDEN
Switch item=DIMMER_PLAFOND_ZITHOEK
Slider item=DIMMER_TAFEL
Slider item=DIMMER_PLAFOND
Slider item=DIMMER_PLAFOND_MIDDEN
Slider item=DIMMER_PLAFOND_ZITHOEK
Frame label="Overige" {
Switch item=SHUTTERS
Switch item=Switch_D
