Although this switch doesn´t have an automatic report function, OH1 displays this item as “enabled”, although it´s switched off. This happens approx 15 minutes after the device is switched off.
Is there any item parameter to avoid this? When the switch is OFF it should be displayed as OFF, unless I switch it ON again.
Thanks!
