Hi all,
I am on OH stable release I have sometime seen my sonoff POWs not switch off when they are supposed to and walk into a room which is boiling hot as it should have been stopped hours ago.
Now I appreciate there are many ways to do heating systems etc, But that is not what is bothering me today.
here is my current (much played around with) rule
RULE
rule "Check POW switches off"
Member of gPOW received command OFF
logInfo("check-state","The POW check status has been triggered by: "+triggeringItem.name)
// check if POW is actually off
val sourceRoom = triggeringItem.name.split("_").get(0)
var sourceRoomName = transform("MAP", "Room_NamesSingle.map", sourceRoom.toString)
val _TTS = sourceRoom+"_Echo_TTS"
val _Notify = sourceRoom+"_Echo_Notify"
val _Device = triggeringItem.name.split("_").get(1)
val _Voltage = gPOWVoltage.members.findFirst[ voltage | voltage.name == sourceRoom+"_"+_Device+"_Voltage" ]
//val _Trigger = triggeringItem.name
val _Trigger = gPOW.members.findFirst[ trigger | trigger.name == sourceRoom+"_"+_Device ]
if (sourceRoom===null || _Device===null || _Voltage===null || _Voltage== NULL ) {
logWarn("check-state","A required value was null / NULL : sourceRoom="+sourceRoom+" _Device="+_Device+" _Voltage="+_Voltage)
return;
} else {
logInfo("check-state","sourceRoom="+sourceRoom+" _Device="+_Device+" _Voltage="+_Voltage.state)
createTimer(now.plusSeconds(2)) [ | {
logInfo("check-state","2 seconds past "+_Voltage.state)
if (_Voltage.state!=0) {
sendCommand(_Trigger.toString,OFF)
logInfo("check-state","1 - 2 seconds resend command to "+_Trigger.toString)
createTimer(now.plusSeconds(5)) [ | {
logInfo("check-state","5 seconds past "+_Voltage.state)
createTimer(now.plusSeconds(8)) [ | {
logInfo("check-state","8 seconds past "+_Voltage.state)
if ((_Voltage.state!=0 || _Voltage.state==NULL) && sleep.state==ON) {
logInfo("check-state","The "+sourceRoom+" "+_Device+" was requested to be switched off but it is still on.")
if (LR_Echo_Notify.state != OFF) {LR_Echo_TTS.sendCommand(sourceRoomName+" "+_Device+" was requested to be switched off but it is still on.")}
if (BR4_Echo_Notify.state != OFF) {BR4_Echo_TTS.sendCommand(sourceRoomName+" "+_Device+" was requested to be switched off but it is still on.")}
logInfo("check-state","13 seconds past "+_Voltage.state)
if (sourceRoom!="LR" && sourceRoom!="BR4") {
val message = sourceRoomName + " " + _Device + " was requested to be switched off but it is still on."
if (_Notify.state != OFF) {_TTS.sendCommand(message)}
} else if (_Voltage.state==0) {logInfo("check-state","Voltage check was 0 - successful: "+triggeringItem.name)}
The issue I am having is when the use case occurs that the device has not switched off and the 2 second timer fires, if the voltage reading is not zero then it should send an OFF command once again to the item that triggered the rule.
Instead it throws a set of exceptions, can someone advise how to correct the function to meet my objective?
The error that is thrown is shown below:
LOG
2019-09-29 01:11:40.558 [INFO ] [e.smarthome.model.script.check-state] - 2 seconds past 215
2019-09-29 01:11:40.561 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-09-29T01:11:40.556+12:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
logInfo(<XStringLiteralImpl>,<XBinaryOperationImplCustom>)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@14a2abd0
} ] threw an unhandled Exception:
java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1103) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:865) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:224) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:460) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy184.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [108:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [108:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1086) ~[?:?]
... 32 more
2019-09-29 01:11:40.626 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-09-29T01:11:40.556+12:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [108:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.IllegalStateException: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
Paul
