I have a physical switch at home and when I press it, in the log, I can see clearly his status going to ON and when I release the physical switch, I can see it going to OFF.
Now I would like to execute 1 action if I press the physical switch for 1 second and another action if I press it for 3 seconds.
Thanks for the answer. I don’t think this would work because if I wait 3 seconds, it should not do the think for 1 seconds.
With your proposal, it would then do the thing after one second then the one after 3 seconds so it would do both. I would like to do either the first action either the second action…
It’s a bit more complicated than that, but first you’ll have to clarify what you want to happen -
If button pressed less than one second (as most of us do)
If button pressed twice within 3 seconds
If the 1-sec action should be carried out whether or not the button is still being held down (for a possible 3 secs)
If you’re happy for the rule to execute when the switch turns off:
var long whenStarted
rule "Button Pressed"
Item buttonX changed from OFF to ON
whenStarted=now.millis
rule "Button Released"
Item buttonX changed from ON to OFF
val whenStopped = now.millis
val timeTaken = whenStopped-whenStarted
if (timeTaken < 3000) {
// Do something
} else {
// Do something else
