Hello guys,
I use openhab 2.4 and the MQTT binding 2.4. however, i don’t use the PaperUI for configuring the broker, I use the openhab2 folders on my Raspberry Pi instead and it works fine.
I want to switch a relay with a NodeMCU (ESP8266) and openhab2. I programmed it with the Arduino IDE. in the picture below you can see the serial monitor of the nodeMCU, MQTT.fx and my openhab site of the switch.
Here is my problem. Only when I have pressed the switch 30 times I hear a click from my relay. As you can see on the serial monitor the message “Z1ON” or “Z1OFF” doesn’t always reach my ESP and I’m helpless. Do any of you know why?
My arduino Code for the NodeMCU:
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <WiFiManager.h>
#define wifi_ssid "SSID" //enter your WIFI SSID
#define wifi_password "MY PASSWORD" //enter your WIFI Password
#define mqtt_server "MY IP ADRESS" // Enter your MQTT server address or IP.
#define mqtt_device "SmartMCU" //MQTT device for broker and OTA name
#define mqtt_user "openhabian" //enter your MQTT username
#define mqtt_password "openhabian" //enter your password
//#define channel1 D0
//#define channel1pub "MCU/channel1"
int channel1 = 16;
const char* channel1pub = "MCU/channel1";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
char message_buff[100];
void callback(char* topic, byte* payload, unsigned int length)
int i = 0;
Serial.println("Message arrived: topic: " + String(topic));
Serial.println("Length: " + String(length,DEC));
// create character buffer with ending null terminator (string)
for(i=0; i<length; i++) {
message_buff[i] = payload[i];
message_buff[i] = '\0';
String msgString = String(message_buff);
Serial.println("Payload: " + msgString);
int state = digitalRead(channel1); // get the current state of GPIO1 pin
if (msgString == "Z1ON"){ // if there is a "1" published to any topic (#) on the broker then:
digitalWrite(channel1, HIGH); // set pin to the opposite state
Serial.println("Switching Z1 ON");
client.publish(channel1pub, "Z1ON");
else if(msgString == "Z1OFF")
digitalWrite(channel1, LOW ); // set pin to the opposite state
Serial.println("Switching Z1 OFF");
client.publish(channel1pub, "Z1OFF");
void reconnect()
// Loop until we're reconnected
while (!client.connected())
//Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect(mqtt_device, mqtt_user, mqtt_password)) {
// Serial.println("connected");
// Once connected, publish an announcement...
//client.publish(channel1pub, "hello world");
// ... and resubscribe
client.subscribe(channel1pub);
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup()
pinMode(channel1, OUTPUT);
digitalWrite(channel1, LOW);
//pinMode(channel1, OUTPUT);
//digitalWrite(channel1,HIGH);
Serial.begin(9600);
delay(10);
WiFiManager wifiManager;
//1wifiManager.resetSettings();
wifiManager.autoConnect("SmartMCU");
Serial.println("Connected to network!!!");
Serial.println();
Serial.println();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
void loop()
if (!client.connected())
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 2000)
lastMsg = now;
++value;
//snprintf (msg, 75, "Hey!! I'm alive #%ld", value);
//Serial.print("Publish message: ");
//Serial.println(msg);
//client.publish("<OUT TOPIC>", msg);
