Hi All,
I currently have the following rule running to determine when I am home or at work.
rule "Home Transform"
Item NathanHome received update
if (NathanHome.state == ON){
NathanHomeTransformed.postUpdate("Nathan is Home")
else{
NathanHomeTransformed.postUpdate("Nathan is Out")
rule "Work Transform"
Item NathanWork received update
if (NathanWork.state == ON){
NathanWorkTransformed.postUpdate("Nathan is at Work")
else{ NathanWorkTransformed.postUpdate("Nathan is not at Work")
What I would like to do is combine the 2 rules so that I get the following outputs on one central item.
Either Nathan is home, At work, Out.
I’ve tried a few different ways but cannot get the desired output.
