I want to implement an Weekdey Option list (using a Switch or Selection).
It should be possible to select more than one Day, e.g. Monday and Thursday.
I tried below but I’m only able to choose a single day, never multiple.
The idea was that if button Monday and Thursday is pressed, the resulting number is 9.
Any idea how to achieve this, with a single item? Or do I have to set a item for each weekday?
With a single item, no. Why don’t you simply use an item per weekday and a rule to “condense” the input list into a single number (if you really want to have it like that).
Note that if you do have an Item per weekday, you could put your seven switch widgets in a “sub-page”, normally out of sight.
The line to open that sub-page could be a dummy string Item, that your rules can populate with something like “S M - W - F S -” to give a visual overview.
