- Platform information:
- Hardware: x86
- OS: Ubuntu 20.04.3 LTS
- Java Runtime Environment: openjdk version “11.0.11”
- openHAB version: 3.1.0 release
- Issue of the topic: Switch state output in Basic UI shows redundant value label
I use OpenHAB with a bunch of Ikea TRÅDFRI devices and today I added a new dimmable lightbulb as an OpenHAB item.
The new brightness item (BadLampe_Helligkeit) behaves differently in Basic UI, compared to an item added with an older version of OpenHAB (example: EsstischLampe1_Helligkeit).
Here is the JSON output of the /rest/items/ endpoint for the two items:
"category": "DimmableLight",
"editable": true,
"groupNames": [
"BadLampe"
"label": "Helligkeit",
"link": "http://openhab.fritz.box:8080/rest/items/BadLampe_Helligkeit",
"name": "BadLampe_Helligkeit",
"state": "100",
"stateDescription": {
"maximum": 100,
"minimum": 0,
"options": [],
"pattern": "%d %%",
"readOnly": false
"tags": [
"Lighting",
"Point"
"type": "Dimmer"
"editable": true,
"groupNames": [
"EsstischLampe1"
"link": "http://openhab.fritz.box:8080/rest/items/EsstischLampe1_Helligkeit",
"name": "EsstischLampe1_Helligkeit",
"state": "58",
"tags": [
"Lighting",
"Point"
"type": "Dimmer"
In Basic UI I use the same controls for the old and the new lightbulb:
Frame label="Bad" {
Switch item=BadLampe_Helligkeit icon="switch" label="An/Aus"
Slider item=BadLampe_Helligkeit icon="light" label="Helligkeit [%d %%]"
Frame label="Esstisch" {
Switch item=EsstischLampe1_Helligkeit icon="switch" label="An/Aus"
Slider item=EsstischLampe1_Helligkeit icon="light" label="Helligkeit [%d %%]"
But the output looks different, for new newly created item, next to the switch state output, the current brightness is shown:
I would guess the the stateDescription property of the newly created item causes the output in Basic UI.
So, here is the question: How can I remove the redundant label with the lightbulb brightness next to the switch state output?
