Garbisa
(Garbisa)
October 30, 2022, 4:20pm
#1
The following code was running fine till I upgraded to iOS16
Switch item=Energy_Chart_Period label="Power(kW)" mappings=[0="Hour", 1="Day"]
Chart item=Electric period=h refresh=6000 visibility=[Energy_Chart_Period==0]
Chart item=Electric period=D refresh=6000 visibility=[Energy_Chart_Period==1]
The buttons do not issue any action.
Matze0211
(Matthias)
October 31, 2022, 7:04am
#2
If it’s a default switch, try with ON / OFF instead of 0/1
Garbisa
(Garbisa)
October 31, 2022, 7:29am
#3
To clarify: the Switch entry does display two buttons “Hour” and “Day”. Using it should display the chart of “Electric per hour” or “Electric per Day”
Matze0211
(Matthias)
October 31, 2022, 8:03am
#4
Show us your log files, what’s happening when you click on the switch button
Garbisa
(Garbisa)
November 1, 2022, 12:51pm
#5
I did some more testing. The item change event is triggered mostly (I checked this in the event log) if I press the button 2 or 3 times fast. Only once, or slowly multiple times will not trigger the event.
rossko57
(Rossko57)
November 1, 2022, 1:16pm
#6
Just to clarify, poking the button in the UI does not directly affect or change the Item state at all. It’s supposed to issue a command to the Item, so that is your events.log
entry of interest here
Garbisa
(Garbisa)
November 1, 2022, 1:31pm
#7
Hi
there are no log-events at all, because all this is handled by the GUI itself. So I’ve no events witch are fired…
I think it is simple: using GUI on windows → single click, using iOS GUI → double click
Garbisa
(Garbisa)
November 1, 2022, 1:35pm
#8
Here the event.log entries if the button is really fired:
2022-11-01 14:26:24.644 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Energy_Chart_Period' received command 0
2022-11-01 14:26:24.644 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Energy_Chart_Period' changed from 1 to 0
system
(system)
Closed
December 13, 2022, 5:36am
#9
