Hello
I have a Problem and dont know how to get a solution …
When i add a switch with mappings to my sitemap like:
Switch item=AL_STATS label="TestSw:" mappings=[0="Test1", 1="Test2", 2="Test2"]
I get the following error:
2017-11-07 21:27:40.625 [ERROR] [.core.internal.folder.FolderObserver] - Error handling update of file '/etc/openhab2/sitemaps/whg.sitemap': null.
java.lang.NullPointerException
at org.eclipse.smarthome.io.rest.sitemap.internal.PageChangeListener.getAllItems(PageChangeListener.java:125)[117:org.eclipse.smarthome.io.rest.sitemap:0.9.0.b5]
at org.eclipse.smarthome.io.rest.sitemap.internal.PageChangeListener.updateItemsAndWidgets(PageChangeListener.java:75)[117:org.eclipse.smarthome.io.rest.sitemap:0.9.0.b5]
at org.eclipse.smarthome.io.rest.sitemap.internal.PageChangeListener.sitemapContentChanged(PageChangeListener.java:217)[117:org.eclipse.smarthome.io.rest.sitemap:0.9.0.b5]
at org.eclipse.smarthome.io.rest.sitemap.SitemapSubscriptionService.modelChanged(SitemapSubscriptionService.java:277)[117:org.eclipse.smarthome.io.rest.sitemap:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:286)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:136)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:234)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:297)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:206)[98:org.eclipse.smarthome.core:0.9.0.b5]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
If i remove it everything works fine …
Sorry for my bad english
