I am trying to use a switch that displays the value received from the device using MQTT. I can get the command working no problem but I am having trouble with the status unless I have the device send ON and OFF instead of 1 or 0 like I want.
Item:
Switch LED "LED [%s]" {mqtt=">[mosquitto:openhab/LEDcommand:command:ON:1],>[mosquitto:openhab/LEDcommand:command:OFF:0],<[mosquitto:openhab/LEDstatus:state:default]"}
Sitemap:
Switch item=LED icon=<bulb>
I also tried using a map with the item where:
onoff.map:
0=OFF
1=ON
and the item was:
Switch LED "LED [MAP(onoff.map):%s]" {mqtt=">[mosquitto:openhab/LEDcommand:command:ON:1],>[mosquitto:openhab/LEDcommand:command:OFF:0],<[mosquitto:openhab/LEDstatus:state:MAP(onoff.map)"}
What am I doing wrong?
