I have a switch working perfectly in PaperUI Control which is great. I have added the switch in sitemap via the .sitemap file and it is showing only it doesn’t switch the light on when I toggle the switch. I suppose it doesn’t know the connection (guess) Am I missing a step in linking it? Or does anyone have an idea on what I am doing incorrectly please?
Very new to this but it is progressing quite well so far.
Wow that’s a bit rude lol. I have stated what I have done and googled alot on how to link openhab sitemap to a paperui control and thought that I would use this forum for the first time and get that posted. Geez man what’s your problem? Isn’t this a forum for people that need help? If not then I do apologise.
All other items work correctly except the Robo500 and mqtt Kitchen one as they we guide that I tried and failed with lol. Strange that the TapestryOne is not working. That is the one that I am trying to get to work. If I go to PaperUi and control and try switching on the thing called TapestryOne then the device switches on perfectly.
Okay, the “Switch” and “Text” and so on that you put in a sitemap tell the UI what widget to use to display/control that Item. The widget isn’t directly related to the Item type.
So …
You cannot control anything with that. Regardless of what type of Item mqtt_kitchen_gas is, the Text widget instructs the UI to display just text without any controls.
Alright, let’s look at that.
Sitemap
Switch item=TapestryOne
This looks good, the UI will show a switch widget.
Items
Switch TapestryOne “Tapestry One” [Switchable]
The Item type is Switch, so that looks good too. The name matches, so when you click the switch in the UI it will send an ON or OFF command to your Item.
You can check that by looking in the events.log file.
The Item does not appear to be linked to any channel or binding, so nothing else will happen. What were you expecting to happen?
To look into that we would like to see the Item definition for that as well.
Perhaps you could look into your events.log to see what happens there.
