mostly using Paper UI, but also experimenting with all other UIs
Hi All,
I recently switched from fhem to openhab2 and have two questions around Rolleshutter & HM-LC-Bl1PBU-FM:
Inverse: openhab2 inverses the meaning of 0% and 100%, i.e. under Homematic 0% means the Blinds are all the way down, whereas the Rollerhutter item displays 100% for the same state. Not much of an issue, but fhem offered to inverse the interpretation. Does openhab2 also offer that?
Precision: I need half percent precision to open the blinds with a desired angle, e.g. in openhab2 to 98,5%. I can indeed set that value via openhab2. It get’s properly transmitted to Homematic and the state in Homematic is (inverse) set to 1,5% as desired. But when reading the value back, openhab2/Rollershutter rounds to 99%. How can I increase the precision of Rollershutter items?
You can use transforms or proxy items and rules to invert the percents.
I think Rollershutter saves state as a PercentType which only supports integer values between 0 and 100. I’m surprised it gets transmitted properly in the first place. You might be able to make something work using a Number Item but that won’t accept UP/DOWN commands. You could also use a proxy Number item to show on your Sitemap.
I would imagine if that were a common need it would have been implemented in the many years since Rollershutter was implemented. This is the first I’ve seen it mentioned on this forum or the old Google Groups forum.
This isn’t too say you shouldn’t file an issue. But realize that it would be a pretty significant change to the way Rollershutter had always worked and likely cause breaking changes to many people’s Rules, so it is kind of a big deal. We can’t just change PercentType because that is used all over the place in other Item types.
This issue would need to be filled at the ESH repo.
