Has anyone been able to pair these bulbs with this Zigbee Ember device? I’m running version 2.4.0 of the Zigbee binding. The zigbee coordinator shows as online and it appears to be taking the discovery command but nothing shows up.
Regards,
-Ryan
Regards,
-Ryan
It is recommended you use HABmin to administer Zigbee devices.I have the same stick but just use the Z-Wave controller.
It is also recommended by the developer to run a new version of the binding. there is an install script that can help you install a new binding on 2.4
Thank you for the reply. The result is no different in Habmin. I believe I have the most recent version of the binding, the 2.4.0 snapshot was last updated December of 2018 but I switched to it regardless.
I’d rather not move to testing / snapshot unless someone can confirm that the hardware I mentioned does in-fact work.
No - 2.4 is very old. You really should use 2.5.
It works with Z-Wave. I do not have amt Zigbee devices to test with. I am running the latest testing version, 2.5M3
The HUSBZB-1 works fine.
Try resetting the bulbs, even if they are brand new, and then do the discovery.
