I don’t know if this question belongs in the Runtime or bindings section
So correct me if I’m wrong
I know there are already a lot of topics about this but none are clear to me
i’m in the process off installing openhab2 the proper way according to Manual installation
Openhab2 automatically starts when my system boot’s (Ubuntu 16.04)
I made my USB-serial devices persistent with a udev rules
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="tty100", GROUP="dialout", MODE="0666"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="tty150", GROUP="dialout", MODE="0666"
I now have /dev/tty100 and tty150 available
but these are not recognized within openhab2/karaf ( “Status: OFFLINE - COMMUNICATION_ERROR Serial Error: Port /dev/tty150/ does not exist” in paper UI - Z-Wave Serial Controller)
I have read a lot of topics about “export EXTRA_JAVA_OPTS=-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0”
( i.e. https://github.com/openhab/openhab-distro/pull/111/commits/585d62ff4366e258c63f7b3494f9f54291b2ec30 )
If I understand it correctly, this has to make to make my NONE default serial port known in java/karaf!?
I’m not sure where to place this export code/rule in openhab2 (i.e. start.sh). There is so many different information about this subject.
Some work only when openhab2 is started manually, according to what I read.
I hope someone here has experience with this and can point me in the right direction.
Perhaps this has been clearly documented! but I have not found it yet
Thank you in advance,
Michiel
