- Platform information:
- Hardware: Suno DS216j ARM 32 bits
- OS: DSM 6.2.1
- Java Runtime Environment: Java 7 (7.0.171) and Java 8 (8.0.161)
- openHAB version: 2.3.0
- Issue of the topic: Java path not correct at reboot
I installed OpenHAB using the SPK (v [2.3.0.005]). As it requires Java8, I installed the packet right BEFORE the SPK, Java7 packet was already installed several weeks before.
INstalling in that condition works fine !
But at reboot, it doesn’t work anymore, because it says the Java version is not correct !
At the NAS reboot the $PATH points to Java7 (I guess that somehow the Java8 installation is not updating the env variable).
I guess that OpenHAB uses the $PATH variable to determine where to find the Java8 files. Which, in that case, is problematic.
I found nowhere a way to force OpenHAB to look into a specific directory for the Java8 files.
Is there a way to do so ?
(I would prefer not uninstalling Java7 nor modify $PATH env var because I’ve got other services relying on it).
