Currently trying to install openHAB on my synology diskstation but having problems with sitemaps not discovering in basicUI
What i have done so far:
Installed openHAB-2.3.0.001-SNAPSHOT-syno-noarch-0.001.spk with succes.
OpenHAB is installed in:
-\192.168.1.9\public\openHAB
with the subfolders being:
-\192.168.1.9\public\openHAB\userdata
-\192.168.1.9\public\openHAB\addons
-\192.168.1.9\public\openHAB\conf
All the readme files and subfolders show up after installation
Set r/w permissons for the openHAB user in controlpanel for the public folder inside synology diskstation.
Created a default.sitemap in \192.168.1.9\public\openHAB\conf\sitemaps\default.sitemap as a .txt file.
Declared the default sitemap location to “default” in paperUI.
And now i get the error in basicUI “Available sitemaps, It seems like you have not defined any sitemaps yet. To build one, please check the documentation for guidance.”
@Gabriel_G untick the option Hide extensions of known file types for you explorer.
Then you will see that your files are called default.sitemap.txt but it has to be called default.sitemap and the items file default.items . This can be seen at the filetype column.
@Josar Huge thanks to you! You were completly correct. I created the files with the normal windows notepad, so all the files were saved as test.items.txt instead og test.items… Fixed this using notepad++ and saving as .items and .sitemap
