- Platform information:
- Rasberry PI3_
- OS: NU/Linux (Raspbian)
- openjdk version “1.8.0_222”
- openHAB 2.5.0-1 :
I stopped Openhab service via openhan-cli, run on debug mode , than stopped and start the service normally, i rebooted the system. then all of things became inactive. So i decided to remove all of the things hopening for recovery.
My system is unable to detect things even thought i have things . and items files configured
any idea?
Here is my log
2020-04-19 15:23:00.367 [temChannelLinkRemovedEvent] - Link ‘iTB_shutter => openwebnet:bus_automation:mybridge:TB_shutter:shutter’ has been removed.
2020-04-19 15:23:00.372 [temChannelLinkRemovedEvent] - Link ‘iB1_switch => openwebnet:bus_on_off_switch:mybridge:B1_switch:switch’ has been removed.
2020-04-19 15:23:00.376 [temChannelLinkRemovedEvent] - Link ‘iF8_switch => openwebnet:bus_on_off_switch:mybridge:F8_switch:switch’ has been removed.
2020-04-19 15:23:00.380 [temChannelLinkRemovedEvent] - Link ‘iCG_switch => openwebnet:bus_on_off_switch:mybridge:CG_switch:switch’ has been removed.
2020-04-19 15:23:00.385 [temChannelLinkRemovedEvent] - Link ‘iTD_shutter => openwebnet:bus_automation:mybridge:TD_shutter:shutter’ has been removed.
2020-04-19 15:23:00.390 [temChannelLinkRemovedEvent] - Link ‘iS0_switch => openwebnet:bus_on_off_switch:mybridge:S0_switch:switch’ has been removed.
2020-04-19 15:23:00.394 [temChannelLinkRemovedEvent] - Link ‘iDS_switch => openwebnet:bus_on_off_switch:mybridge:DS_switch:switch’ has been removed.
2020-04-19 15:23:00.399 [temChannelLinkRemovedEvent] - Link ‘iE4_switch => openwebnet:bus_on_off_switch:mybridge:E4_switch:switch’ has been removed.
2020-04-19 15:23:00.403 [temChannelLinkRemovedEvent] - Link ‘iTF_shutter => openwebnet:bus_automation:mybridge:TF_shutter:shutter’ has been removed.
2020-04-19 15:23:50.514 [temChannelLinkRemovedEvent] - Link ‘iCM_switch => openwebnet:bus_on_off_switch:mybridge:CM_switch:switch’ has been removed.
2020-04-19 15:23:50.528 [temChannelLinkRemovedEvent] - Link ‘iTA_shutter => openwebnet:bus_automation:mybridge:TA_shutter:shutter’ has been removed.
2020-04-19 15:23:50.534 [temChannelLinkRemovedEvent] - Link ‘iF2_switch => openwebnet:bus_on_off_switch:mybridge:F2_switch:switch’ has been removed.
2020-04-19 15:23:50.541 [temChannelLinkRemovedEvent] - Link ‘iCEN2_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN2_energy:power’ has been removed.
2020-04-19 15:23:50.543 [temChannelLinkRemovedEvent] - Link ‘iFH_switch => openwebnet:bus_on_off_switch:mybridge:FH_switch:switch’ has been removed.
2020-04-19 15:23:50.545 [temChannelLinkRemovedEvent] - Link ‘iTH_shutter => openwebnet:bus_automation:mybridge:TH_shutter:shutter’ has been removed.
2020-04-19 15:23:50.547 [temChannelLinkRemovedEvent] - Link ‘iCU_switch => openwebnet:bus_on_off_switch:mybridge:CU_switch:switch’ has been removed.
2020-04-19 15:23:50.549 [temChannelLinkRemovedEvent] - Link ‘iTC_shutter => openwebnet:bus_automation:mybridge:TC_shutter:shutter’ has been removed.
2020-04-19 15:23:50.551 [temChannelLinkRemovedEvent] - Link ‘iF7_switch => openwebnet:bus_on_off_switch:mybridge:F7_switch:switch’ has been removed.
2020-04-19 15:23:50.556 [temChannelLinkRemovedEvent] - Link ‘iST_switch => openwebnet:bus_on_off_switch:mybridge:ST_switch:switch’ has been removed.
2020-04-19 15:23:50.560 [temChannelLinkRemovedEvent] - Link ‘iT5_switch => openwebnet:bus_on_off_switch:mybridge:T5_switch:switch’ has been removed.
2020-04-19 15:23:50.562 [temChannelLinkRemovedEvent] - Link ‘iB3_switch => openwebnet:bus_on_off_switch:mybridge:B3_switch:switch’ has been removed.
2020-04-19 15:23:50.574 [temChannelLinkRemovedEvent] - Link ‘iFG_switch => openwebnet:bus_on_off_switch:mybridge:FG_switch:switch’ has been removed.
2020-04-19 15:23:50.580 [temChannelLinkRemovedEvent] - Link ‘iT8_switch => openwebnet:bus_on_off_switch:mybridge:T7_switch:switch’ has been removed.
2020-04-19 15:23:50.602 [temChannelLinkRemovedEvent] - Link ‘iT7_shutter => openwebnet:bus_automation:mybridge:T6_shutter:shutter’ has been removed.
2020-04-19 15:23:50.604 [temChannelLinkRemovedEvent] - Link ‘iE3_switch => openwebnet:bus_on_off_switch:mybridge:E3_switch:switch’ has been removed.
2020-04-19 15:23:50.606 [temChannelLinkRemovedEvent] - Link ‘iBG_switch => openwebnet:bus_on_off_switch:mybridge:BG_switch:switch’ has been removed.
2020-04-19 15:23:50.610 [temChannelLinkRemovedEvent] - Link ‘iBR_switch => openwebnet:bus_on_off_switch:mybridge:BR_switch:switch’ has been removed.
2020-04-19 15:23:50.612 [temChannelLinkRemovedEvent] - Link ‘iT4_switch => openwebnet:bus_on_off_switch:mybridge:T4_switch:switch’ has been removed.
2020-04-19 15:23:50.614 [temChannelLinkRemovedEvent] - Link ‘iT2_switch => openwebnet:bus_on_off_switch:mybridge:T2_switch:switch’ has been removed.
2020-04-19 15:23:50.616 [temChannelLinkRemovedEvent] - Link ‘iE1_switch => openwebnet:bus_on_off_switch:mybridge:E1_switch:switch’ has been removed.
2020-04-19 15:23:50.619 [temChannelLinkRemovedEvent] - Link ‘iTG_shutter => openwebnet:bus_automation:mybridge:TG_shutter:shutter’ has been removed.
2020-04-19 15:23:50.621 [temChannelLinkRemovedEvent] - Link ‘iT6_switch => openwebnet:bus_on_off_switch:mybridge:T6_switch:switch’ has been removed.
2020-04-19 15:23:50.623 [temChannelLinkRemovedEvent] - Link ‘iI3_switch => openwebnet:bus_on_off_switch:mybridge:I3_switch:switch’ has been removed.
2020-04-19 15:23:50.625 [temChannelLinkRemovedEvent] - Link ‘iTE_shutter => openwebnet:bus_automation:mybridge:TE_shutter:shutter’ has been removed.
2020-04-19 15:23:50.627 [temChannelLinkRemovedEvent] - Link ‘iE5_switch => openwebnet:bus_on_off_switch:mybridge:E5_switch:switch’ has been removed.
2020-04-19 15:23:50.629 [temChannelLinkRemovedEvent] - Link ‘iF1_switch => openwebnet:bus_on_off_switch:mybridge:F1_switch:switch’ has been removed.
2020-04-19 15:23:50.631 [temChannelLinkRemovedEvent] - Link ‘iE2_switch => openwebnet:bus_on_off_switch:mybridge:E2_switch:switch’ has been removed.
2020-04-19 15:23:50.633 [temChannelLinkRemovedEvent] - Link ‘iSR_switch => openwebnet:bus_on_off_switch:mybridge:SR_switch:switch’ has been removed.
2020-04-19 15:23:50.635 [temChannelLinkRemovedEvent] - Link ‘iT3_switch => openwebnet:bus_on_off_switch:mybridge:T3_switch:switch’ has been removed.
2020-04-19 15:23:50.637 [temChannelLinkRemovedEvent] - Link ‘iCEN1_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN1_energy:power’ has been removed.
2020-04-19 15:23:50.640 [temChannelLinkRemovedEvent] - Link ‘iSP_switch => openwebnet:bus_on_off_switch:mybridge:SP_switch:switch’ has been removed.
2020-04-19 15:23:50.642 [temChannelLinkRemovedEvent] - Link ‘iT1_switch => openwebnet:bus_on_off_switch:mybridge:T1_switch:switch’ has been removed.
2020-04-19 15:23:50.644 [temChannelLinkRemovedEvent] - Link ‘iTB_shutter => openwebnet:bus_automation:mybridge:TB_shutter:shutter’ has been removed.
2020-04-19 15:23:50.646 [temChannelLinkRemovedEvent] - Link ‘iB1_switch => openwebnet:bus_on_off_switch:mybridge:B1_switch:switch’ has been removed.
2020-04-19 15:23:50.649 [temChannelLinkRemovedEvent] - Link ‘iF8_switch => openwebnet:bus_on_off_switch:mybridge:F8_switch:switch’ has been removed.
2020-04-19 15:23:50.651 [temChannelLinkRemovedEvent] - Link ‘iCG_switch => openwebnet:bus_on_off_switch:mybridge:CG_switch:switch’ has been removed.
2020-04-19 15:23:50.653 [temChannelLinkRemovedEvent] - Link ‘iTD_shutter => openwebnet:bus_automation:mybridge:TD_shutter:shutter’ has been removed.
2020-04-19 15:23:50.655 [temChannelLinkRemovedEvent] - Link ‘iS0_switch => openwebnet:bus_on_off_switch:mybridge:S0_switch:switch’ has been removed.
2020-04-19 15:23:50.657 [temChannelLinkRemovedEvent] - Link ‘iDS_switch => openwebnet:bus_on_off_switch:mybridge:DS_switch:switch’ has been removed.
2020-04-19 15:23:50.659 [temChannelLinkRemovedEvent] - Link ‘iE4_switch => openwebnet:bus_on_off_switch:mybridge:E4_switch:switch’ has been removed.
2020-04-19 15:23:50.661 [temChannelLinkRemovedEvent] - Link ‘iTF_shutter => openwebnet:bus_automation:mybridge:TF_shutter:shutter’ has been removed.
2020-04-19 15:26:15.651 [.ItemChannelLinkAddedEvent] - Link ‘iFG_switch-openwebnet:bus_on_off_switch:mybridge:FG_switch:switch’ has been added.
2020-04-19 15:26:15.663 [.ItemChannelLinkAddedEvent] - Link ‘iFH_switch-openwebnet:bus_on_off_switch:mybridge:FH_switch:switch’ has been added.
2020-04-19 15:26:15.665 [.ItemChannelLinkAddedEvent] - Link ‘iCU_switch-openwebnet:bus_on_off_switch:mybridge:CU_switch:switch’ has been added.
2020-04-19 15:26:15.667 [.ItemChannelLinkAddedEvent] - Link ‘iSP_switch-openwebnet:bus_on_off_switch:mybridge:SP_switch:switch’ has been added.
2020-04-19 15:26:15.670 [.ItemChannelLinkAddedEvent] - Link ‘iB1_switch-openwebnet:bus_on_off_switch:mybridge:B1_switch:switch’ has been added.
2020-04-19 15:26:15.673 [.ItemChannelLinkAddedEvent] - Link ‘iB3_switch-openwebnet:bus_on_off_switch:mybridge:B3_switch:switch’ has been added.
2020-04-19 15:26:15.677 [.ItemChannelLinkAddedEvent] - Link ‘iF8_switch-openwebnet:bus_on_off_switch:mybridge:F8_switch:switch’ has been added.
2020-04-19 15:26:15.680 [.ItemChannelLinkAddedEvent] - Link ‘iS0_switch-openwebnet:bus_on_off_switch:mybridge:S0_switch:switch’ has been added.
2020-04-19 15:26:15.683 [.ItemChannelLinkAddedEvent] - Link ‘iF7_switch-openwebnet:bus_on_off_switch:mybridge:F7_switch:switch’ has been added.
2020-04-19 15:26:15.685 [.ItemChannelLinkAddedEvent] - Link ‘iDS_switch-openwebnet:bus_on_off_switch:mybridge:DS_switch:switch’ has been added.
2020-04-19 15:26:15.689 [.ItemChannelLinkAddedEvent] - Link ‘iBR_switch-openwebnet:bus_on_off_switch:mybridge:BR_switch:switch’ has been added.
2020-04-19 15:26:15.692 [.ItemChannelLinkAddedEvent] - Link ‘iSR_switch-openwebnet:bus_on_off_switch:mybridge:SR_switch:switch’ has been added.
2020-04-19 15:26:15.695 [.ItemChannelLinkAddedEvent] - Link ‘iCM_switch-openwebnet:bus_on_off_switch:mybridge:CM_switch:switch’ has been added.
2020-04-19 15:26:15.698 [.ItemChannelLinkAddedEvent] - Link ‘iCG_switch-openwebnet:bus_on_off_switch:mybridge:CG_switch:switch’ has been added.
2020-04-19 15:26:15.701 [.ItemChannelLinkAddedEvent] - Link ‘iBG_switch-openwebnet:bus_on_off_switch:mybridge:BG_switch:switch’ has been added.
2020-04-19 15:26:15.704 [.ItemChannelLinkAddedEvent] - Link ‘iF1_switch-openwebnet:bus_on_off_switch:mybridge:F1_switch:switch’ has been added.
2020-04-19 15:26:15.707 [.ItemChannelLinkAddedEvent] - Link ‘iF2_switch-openwebnet:bus_on_off_switch:mybridge:F2_switch:switch’ has been added.
2020-04-19 15:26:15.713 [.ItemChannelLinkAddedEvent] - Link ‘iST_switch-openwebnet:bus_on_off_switch:mybridge:ST_switch:switch’ has been added.
2020-04-19 15:26:15.715 [.ItemChannelLinkAddedEvent] - Link ‘iT1_switch-openwebnet:bus_on_off_switch:mybridge:T1_switch:switch’ has been added.
2020-04-19 15:26:15.717 [.ItemChannelLinkAddedEvent] - Link ‘iT2_switch-openwebnet:bus_on_off_switch:mybridge:T2_switch:switch’ has been added.
2020-04-19 15:26:15.719 [.ItemChannelLinkAddedEvent] - Link ‘iT3_switch-openwebnet:bus_on_off_switch:mybridge:T3_switch:switch’ has been added.
2020-04-19 15:26:15.721 [.ItemChannelLinkAddedEvent] - Link ‘iT4_switch-openwebnet:bus_on_off_switch:mybridge:T4_switch:switch’ has been added.
2020-04-19 15:26:15.723 [.ItemChannelLinkAddedEvent] - Link ‘iT5_switch-openwebnet:bus_on_off_switch:mybridge:T5_switch:switch’ has been added.
2020-04-19 15:26:15.725 [.ItemChannelLinkAddedEvent] - Link ‘iT6_switch-openwebnet:bus_on_off_switch:mybridge:T6_switch:switch’ has been added.
2020-04-19 15:26:15.728 [.ItemChannelLinkAddedEvent] - Link ‘iT7_shutter-openwebnet:bus_automation:mybridge:T6_shutter:shutter’ has been added.
2020-04-19 15:26:15.730 [.ItemChannelLinkAddedEvent] - Link ‘iT8_switch-openwebnet:bus_on_off_switch:mybridge:T7_switch:switch’ has been added.
2020-04-19 15:26:15.731 [.ItemChannelLinkAddedEvent] - Link ‘iE1_switch-openwebnet:bus_on_off_switch:mybridge:E1_switch:switch’ has been added.
2020-04-19 15:26:15.734 [.ItemChannelLinkAddedEvent] - Link ‘iE2_switch-openwebnet:bus_on_off_switch:mybridge:E2_switch:switch’ has been added.
2020-04-19 15:26:15.736 [.ItemChannelLinkAddedEvent] - Link ‘iE3_switch-openwebnet:bus_on_off_switch:mybridge:E3_switch:switch’ has been added.
2020-04-19 15:26:15.738 [.ItemChannelLinkAddedEvent] - Link ‘iE4_switch-openwebnet:bus_on_off_switch:mybridge:E4_switch:switch’ has been added.
2020-04-19 15:26:15.740 [.ItemChannelLinkAddedEvent] - Link ‘iE5_switch-openwebnet:bus_on_off_switch:mybridge:E5_switch:switch’ has been added.
2020-04-19 15:26:15.742 [.ItemChannelLinkAddedEvent] - Link ‘iI3_switch-openwebnet:bus_on_off_switch:mybridge:I3_switch:switch’ has been added.
2020-04-19 15:26:15.744 [.ItemChannelLinkAddedEvent] - Link ‘iTA_shutter-openwebnet:bus_automation:mybridge:TA_shutter:shutter’ has been added.
2020-04-19 15:26:15.746 [.ItemChannelLinkAddedEvent] - Link ‘iTB_shutter-openwebnet:bus_automation:mybridge:TB_shutter:shutter’ has been added.
2020-04-19 15:26:15.748 [.ItemChannelLinkAddedEvent] - Link ‘iTC_shutter-openwebnet:bus_automation:mybridge:TC_shutter:shutter’ has been added.
2020-04-19 15:26:15.750 [.ItemChannelLinkAddedEvent] - Link ‘iTD_shutter-openwebnet:bus_automation:mybridge:TD_shutter:shutter’ has been added.
2020-04-19 15:26:15.752 [.ItemChannelLinkAddedEvent] - Link ‘iTE_shutter-openwebnet:bus_automation:mybridge:TE_shutter:shutter’ has been added.
2020-04-19 15:26:15.754 [.ItemChannelLinkAddedEvent] - Link ‘iTF_shutter-openwebnet:bus_automation:mybridge:TF_shutter:shutter’ has been added.
2020-04-19 15:26:15.756 [.ItemChannelLinkAddedEvent] - Link ‘iTG_shutter-openwebnet:bus_automation:mybridge:TG_shutter:shutter’ has been added.
2020-04-19 15:26:15.759 [.ItemChannelLinkAddedEvent] - Link ‘iTH_shutter-openwebnet:bus_automation:mybridge:TH_shutter:shutter’ has been added.
2020-04-19 15:26:15.761 [.ItemChannelLinkAddedEvent] - Link ‘iCEN1_en_power-openwebnet:bus_energy_central_unit:mybridge:CEN1_energy:power’ has been added.
2020-04-19 15:26:15.763 [.ItemChannelLinkAddedEvent] - Link ‘iCEN2_en_power-openwebnet:bus_energy_central_unit:mybridge:CEN2_energy:power’ has been added.
2020-04-19 15:26:27.191 [thome.event.ExtensionEvent] - Extension ‘package-standard’ has been installed.
2020-04-19 15:27:34.017 [thome.event.ExtensionEvent] - Extension ‘ui-homebuilder’ has been installed.
2020-04-19 15:27:34.036 [thome.event.ExtensionEvent] - Extension ‘misc-market’ has been installed.
2020-04-19 15:27:34.040 [thome.event.ExtensionEvent] - Extension ‘ui-basic’ has been installed.
2020-04-19 15:27:34.044 [thome.event.ExtensionEvent] - Extension ‘misc-openhabcloud’ has been installed.
2020-04-19 15:27:34.048 [thome.event.ExtensionEvent] - Extension ‘persistence-influxdb’ has been installed.
2020-04-19 15:27:34.052 [thome.event.ExtensionEvent] - Extension ‘ui-habpanel’ has been installed.
2020-04-19 15:27:34.056 [thome.event.ExtensionEvent] - Extension ‘ui-paper’ has been installed.
2020-04-19 15:27:39.197 [thome.event.ExtensionEvent] - Extension ‘ui-dashboard’ has been uninstalled.
2020-04-19 15:28:17.858 [temChannelLinkRemovedEvent] - Link ‘iCM_switch => openwebnet:bus_on_off_switch:mybridge:CM_switch:switch’ has been removed.
2020-04-19 15:28:17.860 [temChannelLinkRemovedEvent] - Link ‘iTA_shutter => openwebnet:bus_automation:mybridge:TA_shutter:shutter’ has been removed.
2020-04-19 15:28:17.863 [temChannelLinkRemovedEvent] - Link ‘iF2_switch => openwebnet:bus_on_off_switch:mybridge:F2_switch:switch’ has been removed.
2020-04-19 15:28:17.865 [temChannelLinkRemovedEvent] - Link ‘iCEN2_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN2_energy:power’ has been removed.
2020-04-19 15:28:17.867 [temChannelLinkRemovedEvent] - Link ‘iFH_switch => openwebnet:bus_on_off_switch:mybridge:FH_switch:switch’ has been removed.
2020-04-19 15:28:17.869 [temChannelLinkRemovedEvent] - Link ‘iTH_shutter => openwebnet:bus_automation:mybridge:TH_shutter:shutter’ has been removed.
2020-04-19 15:28:17.871 [temChannelLinkRemovedEvent] - Link ‘iCU_switch => openwebnet:bus_on_off_switch:mybridge:CU_switch:switch’ has been removed.
2020-04-19 15:28:17.874 [temChannelLinkRemovedEvent] - Link ‘iTC_shutter => openwebnet:bus_automation:mybridge:TC_shutter:shutter’ has been removed.
2020-04-19 15:28:17.876 [temChannelLinkRemovedEvent] - Link ‘iF7_switch => openwebnet:bus_on_off_switch:mybridge:F7_switch:switch’ has been removed.
2020-04-19 15:28:17.878 [temChannelLinkRemovedEvent] - Link ‘iB3_switch => openwebnet:bus_on_off_switch:mybridge:B3_switch:switch’ has been removed.
2020-04-19 15:28:17.881 [temChannelLinkRemovedEvent] - Link ‘iST_switch => openwebnet:bus_on_off_switch:mybridge:ST_switch:switch’ has been removed.
2020-04-19 15:28:17.883 [temChannelLinkRemovedEvent] - Link ‘iT5_switch => openwebnet:bus_on_off_switch:mybridge:T5_switch:switch’ has been removed.
2020-04-19 15:28:17.886 [temChannelLinkRemovedEvent] - Link ‘iFG_switch => openwebnet:bus_on_off_switch:mybridge:FG_switch:switch’ has been removed.
2020-04-19 15:28:17.888 [temChannelLinkRemovedEvent] - Link ‘iT8_switch => openwebnet:bus_on_off_switch:mybridge:T7_switch:switch’ has been removed.
2020-04-19 15:28:17.890 [temChannelLinkRemovedEvent] - Link ‘iT7_shutter => openwebnet:bus_automation:mybridge:T6_shutter:shutter’ has been removed.
2020-04-19 15:28:17.893 [temChannelLinkRemovedEvent] - Link ‘iE3_switch => openwebnet:bus_on_off_switch:mybridge:E3_switch:switch’ has been removed.
2020-04-19 15:28:17.895 [temChannelLinkRemovedEvent] - Link ‘iBR_switch => openwebnet:bus_on_off_switch:mybridge:BR_switch:switch’ has been removed.
2020-04-19 15:28:17.897 [temChannelLinkRemovedEvent] - Link ‘iBG_switch => openwebnet:bus_on_off_switch:mybridge:BG_switch:switch’ has been removed.
2020-04-19 15:28:17.899 [temChannelLinkRemovedEvent] - Link ‘iT4_switch => openwebnet:bus_on_off_switch:mybridge:T4_switch:switch’ has been removed.
2020-04-19 15:28:17.901 [temChannelLinkRemovedEvent] - Link ‘iT2_switch => openwebnet:bus_on_off_switch:mybridge:T2_switch:switch’ has been removed.
2020-04-19 15:28:17.903 [temChannelLinkRemovedEvent] - Link ‘iE1_switch => openwebnet:bus_on_off_switch:mybridge:E1_switch:switch’ has been removed.
2020-04-19 15:28:17.906 [temChannelLinkRemovedEvent] - Link ‘iTG_shutter => openwebnet:bus_automation:mybridge:TG_shutter:shutter’ has been removed.
2020-04-19 15:28:17.907 [temChannelLinkRemovedEvent] - Link ‘iT6_switch => openwebnet:bus_on_off_switch:mybridge:T6_switch:switch’ has been removed.
2020-04-19 15:28:17.909 [temChannelLinkRemovedEvent] - Link ‘iI3_switch => openwebnet:bus_on_off_switch:mybridge:I3_switch:switch’ has been removed.
2020-04-19 15:28:17.912 [temChannelLinkRemovedEvent] - Link ‘iTE_shutter => openwebnet:bus_automation:mybridge:TE_shutter:shutter’ has been removed.
2020-04-19 15:28:17.914 [temChannelLinkRemovedEvent] - Link ‘iE5_switch => openwebnet:bus_on_off_switch:mybridge:E5_switch:switch’ has been removed.
2020-04-19 15:28:17.916 [temChannelLinkRemovedEvent] - Link ‘iF1_switch => openwebnet:bus_on_off_switch:mybridge:F1_switch:switch’ has been removed.
2020-04-19 15:28:17.918 [temChannelLinkRemovedEvent] - Link ‘iE2_switch => openwebnet:bus_on_off_switch:mybridge:E2_switch:switch’ has been removed.
2020-04-19 15:28:17.920 [temChannelLinkRemovedEvent] - Link ‘iSR_switch => openwebnet:bus_on_off_switch:mybridge:SR_switch:switch’ has been removed.
2020-04-19 15:28:17.923 [temChannelLinkRemovedEvent] - Link ‘iT3_switch => openwebnet:bus_on_off_switch:mybridge:T3_switch:switch’ has been removed.
2020-04-19 15:28:17.925 [temChannelLinkRemovedEvent] - Link ‘iCEN1_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN1_energy:power’ has been removed.
2020-04-19 15:28:17.927 [temChannelLinkRemovedEvent] - Link ‘iSP_switch => openwebnet:bus_on_off_switch:mybridge:SP_switch:switch’ has been removed.
2020-04-19 15:28:17.929 [temChannelLinkRemovedEvent] - Link ‘iT1_switch => openwebnet:bus_on_off_switch:mybridge:T1_switch:switch’ has been removed.
2020-04-19 15:28:17.931 [temChannelLinkRemovedEvent] - Link ‘iB1_switch => openwebnet:bus_on_off_switch:mybridge:B1_switch:switch’ has been removed.
2020-04-19 15:28:17.933 [temChannelLinkRemovedEvent] - Link ‘iTB_shutter => openwebnet:bus_automation:mybridge:TB_shutter:shutter’ has been removed.
2020-04-19 15:28:17.936 [temChannelLinkRemovedEvent] - Link ‘iF8_switch => openwebnet:bus_on_off_switch:mybridge:F8_switch:switch’ has been removed.
2020-04-19 15:28:17.937 [temChannelLinkRemovedEvent] - Link ‘iCG_switch => openwebnet:bus_on_off_switch:mybridge:CG_switch:switch’ has been removed.
2020-04-19 15:28:17.939 [temChannelLinkRemovedEvent] - Link ‘iTD_shutter => openwebnet:bus_automation:mybridge:TD_shutter:shutter’ has been removed.
2020-04-19 15:28:17.942 [temChannelLinkRemovedEvent] - Link ‘iS0_switch => openwebnet:bus_on_off_switch:mybridge:S0_switch:switch’ has been removed.
2020-04-19 15:28:17.944 [temChannelLinkRemovedEvent] - Link ‘iDS_switch => openwebnet:bus_on_off_switch:mybridge:DS_switch:switch’ has been removed.
2020-04-19 15:28:17.947 [temChannelLinkRemovedEvent] - Link ‘iE4_switch => openwebnet:bus_on_off_switch:mybridge:E4_switch:switch’ has been removed.
2020-04-19 15:28:17.948 [temChannelLinkRemovedEvent] - Link ‘iTF_shutter => openwebnet:bus_automation:mybridge:TF_shutter:shutter’ has been removed.
2020-04-19 15:34:27.453 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:device:mybridge:0’ has been removed.
2020-04-19 15:34:32.043 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:11’ has been removed.
2020-04-19 15:34:37.765 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:12’ has been removed.
2020-04-19 15:34:41.639 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:21’ has been removed.
2020-04-19 15:34:44.833 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:22’ has been removed.
2020-04-19 15:34:57.444 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:23’ has been removed.
2020-04-19 15:35:01.662 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:31’ has been removed.
2020-04-19 15:35:07.752 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘openwebnet:bus_thermostat:mybridge:32’ has been removed.
2020-04-19 15:37:58.283 [temChannelLinkRemovedEvent] - Link ‘iCM_switch => openwebnet:bus_on_off_switch:mybridge:CM_switch:switch’ has been removed.
2020-04-19 15:37:58.288 [temChannelLinkRemovedEvent] - Link ‘iTA_shutter => openwebnet:bus_automation:mybridge:TA_shutter:shutter’ has been removed.
2020-04-19 15:37:58.295 [temChannelLinkRemovedEvent] - Link ‘iF2_switch => openwebnet:bus_on_off_switch:mybridge:F2_switch:switch’ has been removed.
2020-04-19 15:37:58.300 [temChannelLinkRemovedEvent] - Link ‘iCEN2_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN2_energy:power’ has been removed.
2020-04-19 15:37:58.306 [temChannelLinkRemovedEvent] - Link ‘iFH_switch => openwebnet:bus_on_off_switch:mybridge:FH_switch:switch’ has been removed.
2020-04-19 15:37:58.309 [temChannelLinkRemovedEvent] - Link ‘iTH_shutter => openwebnet:bus_automation:mybridge:TH_shutter:shutter’ has been removed.
2020-04-19 15:37:58.311 [temChannelLinkRemovedEvent] - Link ‘iCU_switch => openwebnet:bus_on_off_switch:mybridge:CU_switch:switch’ has been removed.
2020-04-19 15:37:58.314 [temChannelLinkRemovedEvent] - Link ‘iTC_shutter => openwebnet:bus_automation:mybridge:TC_shutter:shutter’ has been removed.
2020-04-19 15:37:58.317 [temChannelLinkRemovedEvent] - Link ‘iF7_switch => openwebnet:bus_on_off_switch:mybridge:F7_switch:switch’ has been removed.
2020-04-19 15:37:58.319 [temChannelLinkRemovedEvent] - Link ‘iST_switch => openwebnet:bus_on_off_switch:mybridge:ST_switch:switch’ has been removed.
2020-04-19 15:37:58.322 [temChannelLinkRemovedEvent] - Link ‘iT5_switch => openwebnet:bus_on_off_switch:mybridge:T5_switch:switch’ has been removed.
2020-04-19 15:37:58.325 [temChannelLinkRemovedEvent] - Link ‘iB3_switch => openwebnet:bus_on_off_switch:mybridge:B3_switch:switch’ has been removed.
2020-04-19 15:37:58.328 [temChannelLinkRemovedEvent] - Link ‘iFG_switch => openwebnet:bus_on_off_switch:mybridge:FG_switch:switch’ has been removed.
2020-04-19 15:37:58.331 [temChannelLinkRemovedEvent] - Link ‘iT8_switch => openwebnet:bus_on_off_switch:mybridge:T7_switch:switch’ has been removed.
2020-04-19 15:37:58.334 [temChannelLinkRemovedEvent] - Link ‘iT7_shutter => openwebnet:bus_automation:mybridge:T6_shutter:shutter’ has been removed.
2020-04-19 15:37:58.336 [temChannelLinkRemovedEvent] - Link ‘iE3_switch => openwebnet:bus_on_off_switch:mybridge:E3_switch:switch’ has been removed.
2020-04-19 15:37:58.341 [temChannelLinkRemovedEvent] - Link ‘iBG_switch => openwebnet:bus_on_off_switch:mybridge:BG_switch:switch’ has been removed.
2020-04-19 15:37:58.343 [temChannelLinkRemovedEvent] - Link ‘iBR_switch => openwebnet:bus_on_off_switch:mybridge:BR_switch:switch’ has been removed.
2020-04-19 15:37:58.344 [temChannelLinkRemovedEvent] - Link ‘iT4_switch => openwebnet:bus_on_off_switch:mybridge:T4_switch:switch’ has been removed.
2020-04-19 15:37:58.346 [temChannelLinkRemovedEvent] - Link ‘iT2_switch => openwebnet:bus_on_off_switch:mybridge:T2_switch:switch’ has been removed.
2020-04-19 15:37:58.348 [temChannelLinkRemovedEvent] - Link ‘iE1_switch => openwebnet:bus_on_off_switch:mybridge:E1_switch:switch’ has been removed.
2020-04-19 15:37:58.350 [temChannelLinkRemovedEvent] - Link ‘iTG_shutter => openwebnet:bus_automation:mybridge:TG_shutter:shutter’ has been removed.
2020-04-19 15:37:58.352 [temChannelLinkRemovedEvent] - Link ‘iT6_switch => openwebnet:bus_on_off_switch:mybridge:T6_switch:switch’ has been removed.
2020-04-19 15:37:58.353 [temChannelLinkRemovedEvent] - Link ‘iI3_switch => openwebnet:bus_on_off_switch:mybridge:I3_switch:switch’ has been removed.
2020-04-19 15:37:58.355 [temChannelLinkRemovedEvent] - Link ‘iTE_shutter => openwebnet:bus_automation:mybridge:TE_shutter:shutter’ has been removed.
2020-04-19 15:37:58.357 [temChannelLinkRemovedEvent] - Link ‘iE5_switch => openwebnet:bus_on_off_switch:mybridge:E5_switch:switch’ has been removed.
2020-04-19 15:37:58.359 [temChannelLinkRemovedEvent] - Link ‘iF1_switch => openwebnet:bus_on_off_switch:mybridge:F1_switch:switch’ has been removed.
2020-04-19 15:37:58.361 [temChannelLinkRemovedEvent] - Link ‘iE2_switch => openwebnet:bus_on_off_switch:mybridge:E2_switch:switch’ has been removed.
2020-04-19 15:37:58.363 [temChannelLinkRemovedEvent] - Link ‘iSR_switch => openwebnet:bus_on_off_switch:mybridge:SR_switch:switch’ has been removed.
2020-04-19 15:37:58.365 [temChannelLinkRemovedEvent] - Link ‘iT3_switch => openwebnet:bus_on_off_switch:mybridge:T3_switch:switch’ has been removed.
2020-04-19 15:37:58.366 [temChannelLinkRemovedEvent] - Link ‘iCEN1_en_power => openwebnet:bus_energy_central_unit:mybridge:CEN1_energy:power’ has been removed.
2020-04-19 15:37:58.368 [temChannelLinkRemovedEvent] - Link ‘iSP_switch => openwebnet:bus_on_off_switch:mybridge:SP_switch:switch’ has been removed.
2020-04-19 15:37:58.370 [temChannelLinkRemovedEvent] - Link ‘iT1_switch => openwebnet:bus_on_off_switch:mybridge:T1_switch:switch’ has been removed.
2020-04-19 15:37:58.372 [temChannelLinkRemovedEvent] - Link ‘iTB_shutter => openwebnet:bus_automation:mybridge:TB_shutter:shutter’ has been removed.
2020-04-19 15:37:58.374 [temChannelLinkRemovedEvent] - Link ‘iB1_switch => openwebnet:bus_on_off_switch:mybridge:B1_switch:switch’ has been removed.
2020-04-19 15:37:58.376 [temChannelLinkRemovedEvent] - Link ‘iF8_switch => openwebnet:bus_on_off_switch:mybridge:F8_switch:switch’ has been removed.
2020-04-19 15:37:58.378 [temChannelLinkRemovedEvent] - Link ‘iCG_switch => openwebnet:bus_on_off_switch:mybridge:CG_switch:switch’ has been removed.
2020-04-19 15:37:58.380 [temChannelLinkRemovedEvent] - Link ‘iTD_shutter => openwebnet:bus_automation:mybridge:TD_shutter:shutter’ has been removed.
2020-04-19 15:37:58.382 [temChannelLinkRemovedEvent] - Link ‘iS0_switch => openwebnet:bus_on_off_switch:mybridge:S0_switch:switch’ has been removed.
2020-04-19 15:37:58.383 [temChannelLinkRemovedEvent] - Link ‘iDS_switch => openwebnet:bus_on_off_switch:mybridge:DS_switch:switch’ has been removed.
2020-04-19 15:37:58.385 [temChannelLinkRemovedEvent] - Link ‘iE4_switch => openwebnet:bus_on_off_switch:mybridge:E4_switch:switch’ has been removed.
2020-04-19 15:37:58.387 [temChannelLinkRemovedEvent] - Link ‘iTF_shutter => openwebnet:bus_automation:mybridge:TF_shutter:shutter’ has been removed.
2020-04-20 11:10:01.204 [ome.event.ItemCommandEvent] - Item ‘iCM_switch’ received command ON
2020-04-20 11:10:01.227 [nt.ItemStatePredictedEvent] - iCM_switch predicted to become NULL
2020-04-20 11:12:02.916 [ome.event.ItemCommandEvent] - Item ‘iCM_switch’ received command ON
2020-04-20 11:12:02.934 [nt.ItemStatePredictedEvent] - iCM_switch predicted to become NULL
2020-04-20 11:51:59.846 [ome.event.ItemCommandEvent] - Item ‘iCM_switch’ received command ON
2020-04-20 11:51:59.853 [nt.ItemStatePredictedEvent] - iCM_switch predicted to become NULL
